Issue with the addSelectionFilter Method of SelectionCommandInput in C++
jan_vokurka
jan_vokurka
while trying out Selection Events API Sample, I came across a problem with the addSelectionInput method of SelectionCommandInput. In the python version of the sample in MyCommandCreatedHandler class:
selectInput = inputs.addSelectionInput('SelectionEventsSample', 'Edges', 'Please select edges')
selectInput.addSelectionFilter(adsk.core.SelectionCommandInput.Edges)
selectInput.setSelectionLimits(1)
Selection Filters, in this case adsk.core.SelectionCommandInput.Edges are used as argument of the addSelectionFilter().
This works fine, however while working with the c++ sample, I found out that the equivalent approach:
bool result = selectInput->addSelectionFilter(adsk::core::SelectionCommandInput::Edges);
returns false, hence no filter was set. Fortunately I can just use string instead and so avoid having to deal with this issue but I was curious if this is a bug or I'm missing something.
pezidek
mistake is in the used argument.
The argument must be a string. In your case "Edges"
bool result = selectInput->addSelectionFilter("Edges");
Petr
jan_vokurka
I realized I need to use string as an argument. I rather wanted to ask, if an equivalent approach that is showcased in the official c++ sample shouldn't work as well..and if not report a bug there 🙂
pezidek
You are right that there is an error in the example, respectively the filter setting is not functional. The fact that it doesn't report any error is because the return value of the ->addSelectionFilter() method is bool. Thus, the filter setting does not take place but the script continues to run.
jan_vokurka
Yes, I only traced the mistake after comparing the two samples.
