Isocurve help
Isocurve help
J_Gow
Isocurve help
J_Gow
Hello all,
My goal is to ultimately write a script to create an Isocurve on a user selected face or faces using the getIsoCurve method.
I am stuck at the beginning just trying to generate an Isocurve.  I'm testing it on individual faces of a very simple patch surface derived from a T-Splines mesh and also on another patch surface extruded from a circle.  The messageBox returns 'None Type' for isocurve:
# Snippet from my code
face0 = ui.selectEntity('Select a Face', 'Faces').entity
isocurve = face0.geometry.evaluator.getIsoCurve(.5, False)
ui.messageBox('Output: {0}'.format(isocurve.objectType))
1.  How do query a face to determine which direction the U and V are?
2.  Am I inputting the correct type of argument for the parameter?
3.  Once an Isocurve is created, is it technically a Curve3D object?
4.  I may be asking a lot of Fusion with this one, is it possible to convert an Isocurve to a spline?
Thank you for your help,
Josh
J_Gow
Please disregard questions 1 and 2, I figured out what I was doing wrong.
I needed to go directly to the Surface Evaluator and not through Geometry.  so now it works:  isocurve  = face.evaluator.getIsoCurve(parameter, bool)
Also, I overlooked that it returns an Object Collection, so now doing  isocurve.count returns 1.
J_Gow
Well, I did some more digging on the forums and ended up finding answers to the rest of my questions.  It's considered a 3d nurbscurve and it can be converted to a spline.
ut15
HI,
if possible to have the list complete script?
kandennti
Hi @ut15 .
I made an experimental one using the getIsoCurve method, but there was no use for it, so I'm releasing it here.
https://github.com/kantoku-code/Fusion360_Small_Tools_for_Developers/blob/master/UVviewer/UVviewer.p...
J_Gow
Wow nice job, you got much further than I did.  I was still learning the API and Fusion at the time and ended up abandoning trying to figure out a script.  However in hindsight I also have not had a need for it.  I'd rather create a curve on a surface using project to surface because the projected curve will recalculate if changes are made to the reference curve.
