Is the SplitButton Toolbar Control Object supported on the QAT?
scottmoyse
Mentor Mentor
Message 1 of 10
scottmoyse
I've been trying to implement a split button on the QAT, but when I follow the format required it doesn't work. Nothing renders on the QAT. The documentation doesn't state if it's supported or not:
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-717b6ac8-6e27-4246-ab55-b00c239b32f0
Has anyone successfully implemented one before? I've had a decent look through the samples and some apps on the store and can see that it appears people have generally avoided using it in places where I would have thought they would use it.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Replies (9)
Message 2 of 10
BrianEkins
I think this is a bug in the API.  I'm not able to get it to work either.
Brian Ekins
Message 3 of 10
scottmoyse
Thanks for giving it a go @BrianEkins i also noticed that the documentation doesn't match between what's installed and on the website... neither way works nonetheless.
Scott Moyse
Message 4 of 10
scottmoyse
@goyals do you know if this has been logged as a bug?
Scott Moyse
Message 5 of 10
goyals
We identified a bug in our python interface files which is highlighted by VSCode. We missed to add 'self' argument as first argument in our API methods. VSCode might be considering first argument of each method as self argument and skipping it in highlighting documentation. Hopefully We will try to fix it early. Thanks.
Shyam Goyal
Sr. Software Dev. Manager
Message 6 of 10
goyals
Hi @scottmoyse, Is it possible If you can share with me a script showing problem? It will help me to quickly validate it. Thanks.
Shyam Goyal
Message 7 of 10
scottmoyse
@goyals I don't have any of the code handy anymore since I've removed it from my add-in. It was a basic implementation following the documentation. As you can see above, @BrianEkins couldn't get it to work either.
Scott Moyse
Message 8 of 10
goyals
No problem. I will check with Brian Ekins for a sample script and log a defect. Thanks.
Shyam Goyal
Message 9 of 10
scottmoyse
It looks like this was fixed in the latest release.
Scott Moyse
Message 10 of 10
goyals
Hi @scottmoyse, Let us know if you still notice any issue. Thanks.
Shyam Goyal
