I want to create a pyramid like object where base is defined by a polygon (a square, triangle, star ... any other) and top is one point. Using UI, it is quite simple. I create sketch for a polygon on XY plane, then I create second sketch on offset plane. Offset is in Z-axis and the distance defines the height of the pyramid. The top point is the only content of the second sketch. Then I use loft feature selecting the polygon area and the point.
I would like to make the same by a python script. But it doesn't work. It throws an exception when I try to get a profile item from the second sketch. I understand that loft feature needs two sketch-profile-items. But as I read in the Fusion 360 API Object Model - Sketches - Profiles a points cannot be a profile-item (only loop).
I can make a workaround by creating a circle with very small (but not zero) radius.
Is it possible to make a loft to one point using API?
thanks
A code for creating star-pyramid. Comment and uncomment code to use circle or point.
import adsk.core, adsk.fusion, adsk.cam, traceback
import math
def roll(field):
# shift items in an array by one in right to left direction
# that first element becomes the last
# example: roll([0, 1, 2, 3]) returns: [1, 2, 3, 0]
# field: array of elements to be shifted
# retruns: shifted
new_field = []
for idx, item in enumerate(field):
if idx == 0:
continue
new_field.append(item)
new_field.append(field[0])
return new_field
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
rootComp = design.rootComponent
# star data
inner_radius = 5
outer_radius = 10
num_of_pikes = 5
z_height = 5
angle = math.pi/num_of_pikes
points = []
trigger = True
for n in range(2*num_of_pikes):
current_angle = n*angle
if trigger:
l = inner_radius
trigger = False
else:
l = outer_radius
trigger = True
x = l * math.cos(current_angle)
y = l * math.sin(current_angle)
z = 0
points.append([x, y, z])
# Create a new sketch on the xy plane.
sketches = rootComp.sketches
xyPlane = rootComp.xYConstructionPlane
sketch0 = sketches.add(xyPlane)
# Draw some circles.
lines = sketch0.sketchCurves.sketchLines
p0 = adsk.core.Point3D.create(points[0][0], points[0][1], points[0][2])
p1 = adsk.core.Point3D.create(points[1][0], points[1][1], points[1][2])
line0 = lines.addByTwoPoints(p0, p1)
for xyz in roll(points):
line1 = lines.addByTwoPoints(line0.endSketchPoint, adsk.core.Point3D.create(xyz[0], xyz[1], xyz[2]))
line0 = line1
# create offset construction plane
# Get construction planes
# Get the profile defined by the circle
sketch_profile0 = sketch0.profiles.item(0)
planes = rootComp.constructionPlanes
# Create construction plane input
planeInput = planes.createInput()
# Add construction plane by offset
offsetValue = adsk.core.ValueInput.createByReal(z_height)
planeInput.setByOffset(sketch_profile0, offsetValue)
planeOne = planes.add(planeInput)
sketch1 = sketches.add(planeOne)
# circle work
sketch1_circles = sketch1.sketchCurves.sketchCircles
sketch1_circles.addByCenterRadius(adsk.core.Point3D.create(0,0,0), 0.0001)
# point doesnt work
# sketch1_points = sketch1.sketchPoints
# sketch1_points.add(adsk.core.Point3D.create(0, 0, 0))
sketch_profile1 = sketch1.profiles.item(0)
# Create an extrusion input
loftFeature = rootComp.features.loftFeatures
loftInput = loftFeature.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
loftSectionsObjects = loftInput.loftSections
loftSectionsObjects.add(sketch_profile0)
loftSectionsObjects.add(sketch_profile1)
loftInput.isSolid = True
# Create loft feature
loftFeature.add(loftInput)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
