Is it possible to add a entry line on the general tab when creating a new tool?
CuttingEdgeManufacturing
want to add a serial number when creating a tool is this possible thru API
EDIT: posted this literally right before lunch and i didnt realize how short it was.
I have an excel sheet with serial numbers for all my tools, i recently learned i could pull data from the .json files to make this list, so it would be great if i could add in a serial number straight out of fusion.
kandennti
Hi @CuttingEdgeManufacturing .
In order to fill in the serial number, I think you need to access the tool library.
Unfortunately, I don't think the current API allows access to the tool library.
Also, the API does not provide a way to create new tool or tool path.
The only way I know of is to use the template import in this sample.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-AEF0708D-B657-4E9F-9032-4535E0D1C417
Try exporting the template file (.f3dhsm-template) in the GUI.
When you open it in an editor, you will see it is in XML format.
You can add a new tool to the tool library by rewriting the <description> value and importing it.
If you do not need the tool path, you can delete it, but the tool will remain.
However, even if you do it this way, you will not be able to do anything further.
i appreciate the feedback, i think i will just use the product link field to put my serial number. i rarely use the product link currently so it shouldnt cause much fuss for me.
