Insert stl file using C++ script.
galaxyblazer
galaxyblazer
There are many samples how to insert .stl or .obj file using Python or JavaScript script. But there are no any sample for C++.
I can't call addByInsert method from :
Ptr<Component> rootComp = design->rootComponent();
auto occ = rootComp->occurrences();
what next should be?
what I doing wrong ?
ekinsb
Here's the full code for a script that displays a dialog to get the filename of an stl or obj file and then inserts it into the active design.  To simplify the sample, there's almost no error handling.
extern "C" XI_EXPORT bool run(const char* context)
	app = Application::get();
	if (!app)
		return false;
	ui = app->userInterface();
	if (!ui)
		return false;
	Ptr<Design> des = app->activeProduct();
	Ptr<FileDialog> fileDialog = ui->createFileDialog();
	fileDialog->filter("Mesh Files (*.STL;*.OBJ);;All files (*.*)");
	if (fileDialog->showOpen() == adsk::core::DialogResults::DialogOK)
		std::string filename = fileDialog->filename();
		Ptr<Component> root = des->rootComponent();
		Ptr<BaseFeature> base = root->features()->baseFeatures()->add();
		base->startEdit();
		Ptr<MeshBody> body = root->meshBodies()->add(filename, adsk::fusion::MeshUnits::CentimeterMeshUnit, base);
		base->finishEdit();
	else
		ui->messageBox("Canceled file dialog.");
	return true;
Brian Ekins
Mod the Machine blog
galaxyblazer
Could you please send includes and using namespaces for this sample .
ekinsb
Here's the complete source.
#include <Core/Application/Application.h>
#include <Core/UserInterface/UserInterface.h>
#include <Core/Application/Product.h>
#include <Fusion/Fusion/Design.h>
#include <Core/UserInterface/FileDialog.h>
#include <Fusion/Components/Component.h>
#include <Fusion/Features/BaseFeature.h>
#include <Fusion/Features/BaseFeatures.h>
#include <Fusion/Features/Features.h>
#include <Fusion/MeshBody/MeshBodies.h>
#include <Fusion/MeshBody/MeshBody.h>
#include <Fusion/MeshBody/MeshBodyList.h>
using namespace adsk::core;
using namespace adsk::fusion;
Ptr<Application> app;
Ptr<UserInterface> ui;
	if (!app)
		return false;
	if (!ui)
		return false;
		base->startEdit();
		base->finishEdit();
	else
	return true;
extern "C" XI_EXPORT bool stop(const char* context)
	if (ui)
		ui->messageBox("in stop");
		ui = nullptr;
	return true;
#ifdef XI_WIN
#include <windows.h>
BOOL APIENTRY DllMain(HMODULE hmodule, DWORD reason, LPVOID reserved)
	switch (reason)
	case DLL_PROCESS_ATTACH:
	case DLL_THREAD_ATTACH:
	case DLL_THREAD_DETACH:
	case DLL_PROCESS_DETACH:
		break;
	return TRUE;
#endif // XI_WIN
Brian Ekins
