Import and Modify STL with Python Scripting
arjun_vermaWKZX3
Observer Observer
arjun_vermaWKZX3
Observer
Observer
Hi all,
I am new to Fusion360 and am looking for some guidance. I have a collection of over 200 STL files which contain the geometry of various irregularly shaped blood vessels (1 inlet, 1 outlet). I need to process them by trimming 5mm off of the inlet and outlet, and then adding a 50mm long cylinder to each end. What are the best ways to get started on this task using Python Scripting?
Any help is much appreciated! Thanks.
rohit_maneYV8C9
Hello @arjun_vermaWKZX3 ,
you can find more details about Fusion API here Fusion API (Application Programming Interface)
You can use the attached script to import multiple STL files into Fusion. However, since these files have irregular shapes, you may need to convert them back into solid bodies for easier editing, as working with mesh files can be quite challenging.
import os
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    try:
        global ui
        app = adsk.core.Application.get()
        ui  = app.userInterface
        if (not ui.activeWorkspace.id == "FusionSolidEnvironment"):
            modelWS = ui.workspaces.itemById("FusionSolidEnvironment")
            modelWS.activate()
        opFolder = GetFolderDialog('Fusion - Select folder location.',os.path.expanduser('~/Documents'))
        doc = app.activeDocument
        products = doc.products
        design = adsk.fusion.Design.cast(products.itemByProductType("DesignProductType"))
        rootComp = design.rootComponent
        design.designType = adsk.fusion.DesignTypes.ParametricDesignType
        for root, dirs, files in os.walk(opFolder):
            for file in files:
                fileName, ext = os.path.splitext(file)
                if ext.lower() in '.stl':
                    tempStl = os.path.join(root, file)
                    baseFeatures = rootComp.features.baseFeatures.add()
                    baseFeatures.startEdit()
                    rootComp.meshBodies.add(tempStl,adsk.fusion.MeshUnits.MillimeterMeshUnit,baseFeatures)
                    baseFeatures.finishEdit()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def GetFolderDialog(title = "" , initialDirectory= ""):
    # Set styles of file dialog.
    FolderDlg = ui.createFolderDialog()
    if title != "" : FolderDlg.title = title
    if initialDirectory != "" : FolderDlg.initialDirectory = initialDirectory
    # Show File dialog
    dlgResult = FolderDlg.showDialog()
    if dlgResult == adsk.core.DialogResults.DialogOK:
        FolderPath = FolderDlg.folder
        if not os.path.isdir(os.path.dirname(FolderPath)):
            ui.messageBox("Selectes folder is not exist")
            return None
    else:
        return None
    return FolderPath
Hope it helps.
