Identify selected (clicked) QAT ListItem from within a CommandEventHandler
How can I identify which ListItem ( within an initialized ListControlDefinitionListItem's collection ) is selected by the user?
These QAT commands ( as they are currently constructed ) do not change any values within Fusion 360. I need them to call an external process with command arguments derived from the button selected.
The CommandEventHandler's args allow for the initialization of the command.parentCommandDefinition.id, but I need a way to retrieve the selected-child command's names and/or ids.
With this in mind, can the ListControlDefinitionListItem's child commands be identified from within a CommandEventHandler?
If this must be done in an InputChangedEventHandler, how do I get the listItems within the QAT to trigger that event?
The current code for the QAT commands is as follows:
commandDefinitions_ = ui.commandDefinitions
toolbars_ = ui.toolbars toolbarQAT_ = toolbars_.itemById('QAT') toolbarControlsQAT_ = toolbarQAT_.controls # add a ListControlDefinition to the Quick Access Toolbar listCmdToolbarCtlQAT_ = toolbarControlsQAT_.itemById(listCmdIdOnQAT) if not listCmdToolbarCtlQAT_: listCmdDefinitionQAT_ = commandDefinitions_.itemById(listCmdIdOnQAT) if not listCmdDefinitionQAT_: listCmdDefinitionQAT_ = commandDefinitions_.addListDefinition(listCmdIdOnQAT, commandName, adsk.core.ListControlDisplayTypes.StandardListType, index_icon) listItems_ = adsk.core.ListControlDefinition.cast(listCmdDefinitionQAT_.controlDefinition).listItems listItems_.add('Index', True, index_icon)
listItems_.add('Log In', False, login_icon)
listItems_.add('Log Out', False, logout_icon) listItems_.add('Post', False, put_icon) listItems_.add('Put', False, post_icon) listItems_.add('Get', False, get_icon) onListCommandCreated = CommandCreatedEventHandlerQAT() listCmdDefinitionQAT_.commandCreated.add(onListCommandCreated) # Persist handler references: handlers.append(onListCommandCreated) listCmdToolbarCtlQAT_ = toolbarControlsQAT_.addCommand(listCmdDefinitionQAT_) listCmdToolbarCtlQAT_.isVisible = True ui.messageBox(('Index command list has been successfully added to the Quick Access Toolbar'))
I'm able to pass the command arguments using standard commandDefinitions like the one shown below, however, I haven't found a way to accomplish the same thing on the QAT using listItems.
# command definitions
index_command = commandDefinitions_.itemById(index_cmd_id)
if not index_command:
index_command = commandDefinitions_.addButtonDefinition(index_cmd_id, 'Index', ".com", './resources/index')
index_command.commandCreated.add(onCommandCreated)
# persist the handler references
onInputChanged = InputChangedHandler()
handlers.append(onCommandCreated)
handlers.append(onInputChanged)
# add commands to the addins panel in modeling workspace
workspaces_ = ui.workspaces
modelingWorkspace_ = workspaces_.itemById(workspaceToUse)
toolbarPanels_ = modelingWorkspace_.toolbarPanels
toolbarPanel_ = toolbarPanels_.itemById(addins_panel)
addins_control_panel = toolbarPanel_.controls
# add the commands to the the addins panel
index_control = addins_control_panel.itemById(index_cmd_id)
if not index_control:
index_control = addins_control_panel.addCommand(index_command, 'index')
index_control.isVisible = True
Any suggestions would be appreciated. Thank you.
