I want to make new Component like using mouse.
maeokaQ2NB3
maeokaQ2NB3
Hi,everyone.
I want to create a new component using the API.In the AddExistingComponent command, the parameters are the same, so I want to know how to make new component(occurrence?) like copy & paste with the mouse.files.JPG
goyals
It would be helpful If you can clarify your question a bit more. AddExistingComponent is meant for copying an existing component through API like copy-paste in UI and AddNewComponent is meant to create new component. Is there any issue you noticed with any of the these two API?
Shyam Goyal
Sr. Software Dev. Manager
maeokaQ2NB3
Thank you very much.
copy & paste components with the mouse, the two components will work separately but addExistingComponent command will move together.
I want to use functions like separate operation ~ paste new
goyals
Paste new functionality is not exposed through API at the moment but I found this workaround posted by one user
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/copy-component-occurrence-paste-new-via-th...
Shyam Goyal
maeokaQ2NB3
It worked well!
