I want to change the modeled property of the hole command.
kandennti
Mentor Mentor
Message 1 of 1
kandennti
Hi everyone,
I am working on a script to switch Modeled for all threads.
Threads are also present in the hole command, but I am unable to switch threads in hole.
Is there any way to switch this?
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        timeline: fusion.Timeline = des.timeline
        state = timeline.markerPosition
        threadList = list(root.features.threadFeatures)
        for occ in root.allOccurrences:
            comp: fusion.Component = occ.component
            threadList.extend(list(comp.features.threadFeatures))
        threadFeat: fusion.ThreadFeature = None
        for threadFeat in threadList:
            try:
                threadFeat.timelineObject.rollTo(True)
                threadFeat.isModeled = not threadFeat.isModeled
                success = "OK"
            except:
                hole = threadFeat.linkedFeatures[0]
                success = "NG"
            finally:
                app.log(f"{threadFeat.name}:{success}")
        timeline.markerPosition = state
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Replies (0)
