How use addExistingComponent under a occurence that is not the top node
seb.quevillon.1
seb.quevillon.1
I would like to know how to add an existing component under a subassembly and not the top node.
In the example below, I would like to copy the "cube" (component ) under  "Cube_Assembly:1" (occurence).
I also attached the fusion file.
Thank you
BrianEkins
I think this should do it.
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root = des.rootComponent
        cubeComp = des.allComponents.itemByName('cube')
        cubeAssemblyComp = des.allComponents.itemByName('Cube_Assembly')
        occ = cubeAssemblyComp.occurrences.addExistingComponent(cubeComp, adsk.core.Matrix3D.create())
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
seb.quevillon.1
Thank you !
