How to use MoveFeatureInput.defineAsPointToPoint
rolandas_vegis
rolandas_vegis
I have been trying to use the method MoveFeatureInput.defineAsPointToPoint, yet I keep getting invalid entity error. Could not find any examples how to use it.
I tried passing: 2 sketch points, a sketch point and vertex, 2 Point3D yet always same error.
So which objects are accepted here?
osamuETYQY
Hi, rolandas_vegis,
The following code worked for me.
If the point belongs to an occurrence of a sub component, you may need to do `p1.createForAssemblyContext(occurence)` when you give it to `defineAsPointToPoint`.
        app = adsk.core.Application.get()
        design = adsk.fusion.Design.cast(app.activeProduct)
        root = design.rootComponent
        sketch = root.sketches.add(root.xYConstructionPlane)
        sketch.sketchCurves.sketchCircles.addByCenterRadius(adsk.core.Point3D.create(), 1)
        cylinder = root.features.extrudeFeatures.addSimple(
            sketch.profiles[0],
            adsk.core.ValueInput.createByReal(1),
            cast(adsk.fusion.FeatureOperations, adsk.fusion.FeatureOperations.NewBodyFeatureOperation),
        p1 = sketch.sketchPoints.add(adsk.core.Point3D.create(0, 0, 0))
        p2 = sketch.sketchPoints.add(adsk.core.Point3D.create(0, 1, 1))
        inp = root.features.moveFeatures.createInput2(adsk.core.ObjectCollection.createWithArray([cylinder.bodies[0]]))
        inp.defineAsPointToPoint(p1, p2)
        root.features.moveFeatures.add(inp)
