how to select teams hub from python API
MortenGuldager
MortenGuldager
I am making a script that will traverse all my designs across all team hubs. Open them one by one and do various operations. (I am on two teams and then have a bunch of personal files as well)
I'm having trouble opening designs on another team hub than the one currently the active one.
Python throws this at me:
RuntimeError: 3 : Design is located in another team.
You may not be able to save changes you make to this design.
I can catch this fine but while the design actually loaded I cant do anything with it since I didn't get the document handle.
Questions:
  • Can I  switch active teams hub using the python API?
  • Other ways around this?
BrianEkins
The API doesn't support activating a hub and you can only work with the contents of a hub in Fusion when that hub is active.  I'm not aware of any workaround.
Brian Ekins
MortenGuldager
Hmm, ok. Is there any API way to tell which hub is actively selected?
hen I can work my way around by instructing the user to do the switch manually if needed.
/mogul
kandennti
Hi @MortenGuldager .
Displays the current team name.
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        ui.messageBox(f'Team Name:{app.data.activeHub.name}')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
