How to see all measurements for a sketch?
deonholt
deonholt
Hi.
I drew up a very basic 4-sided box.
I specified the bottom length, the two sides and the two inside angles.
I connected the two side-lines with a line and F360 determined the length.
How can I teel F360 to show the top side's length as well? (I know I can have F360 telling me what it is by the measure tool, but I want to have ot shown even though it was not specified.)
Thanks very much.
dsouzasujay
Hi @deonholt ,
Just add the another dimension on the Top.
below message will popup
Hit OK..
Basically, you should be able to over constrain.
Not sure if you are looking for the same, Please correct me if i'm wrong.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
deonholt
Thank you very much.
I always hit cancel when the popup showed.
Thanks a million.
