How to prevent ApplicationCommandEventHandler to be called a million times
lichtzeichenanlage
Advisor Advisor
Message 1 of 9
lichtzeichenanlage
I try to create and close a temporary document within the CommandExecuteHandler which forces Fusion 360 to crash. I search the forum and it looks like that the commandTerminated is the solution to this problem but for me a new problem occurs: The function is called "a million times" and I can't prevent this. So any idea how to solve one the two problems?
#Author-Author
#Description-Description
import adsk.core, adsk.fusion, adsk.cam, traceback
TOOLBAR_PANEL_ID = 'MyPanel'
TOOLBAR_PANEL_NAME = 'My Name'
MY_COMMAND_ID = "MyCommand"
MY_COMMAND_NAME = "My Command"
MY_COMMAND_TOOLTIP = "My Description"
# Global set of event handlers to keep them referenced for the duration of the command
_handlers = []
handlers = []
_document = None
class CommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            # Get the command that was created.
            cmd = adsk.core.Command.cast(args.command)
            onExecute = CommandExecuteHandler()
            cmd.execute.add(onExecute)
            _handlers.append(onExecute)
            onExecutePreview = CommandExecutePreviewHandler()
            cmd.executePreview.add(onExecutePreview)
            _handlers.append(onExecutePreview)
            onInputChanged = CommandInputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
            onDestroy = CommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            inputs = cmd.commandInputs
            inputs.addTextBoxCommandInput("idasdf","Name","Hello World!", 1, False)
        except:
            app = adsk.core.Application.get()
            ui = app.userInterface
            ui.messageBox(traceback.format_exc())
class CommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            global _document
            activeDocument = app.activeDocument
            application = adsk.core.Application.get()
            fusionDocType = adsk.core.DocumentTypes.FusionDesignDocumentType
            _document = application.documents.add(fusionDocType)
            # set design type
            design :adsk.fusion.Design = _document.design
            design.designType = adsk.fusion.DesignTypes.DirectDesignType
            # get root component
            rootComponent :adsk.fusion.Component = design.rootComponent
        except:
class CommandExecutePreviewHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs = adsk.core.CommandEventArgs.cast(args)
            eventArgs.isValidResult = False
        except:
class CommandInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            pass
        except:
class CommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            pass
        except:
class MyCommandTerminatedHandler(adsk.core.ApplicationCommandEventHandler):
    def __init__(self):
        super().__init__()
        eventArgs = adsk.core.ApplicationCommandEventArgs.cast(args)
        global _document
        if _document:
            print("Closing " + _document.name)
            _document.close(False)
            _document = None
def run(context):
    try:
        # create panel
        # create panel
        # get toolbarPanels
        allDesignTabs = ui.toolbarTabsByProductType('DesignProductType')
        toolsTab = allDesignTabs.itemById('SolidTab')
        toolbarPanels = toolsTab.toolbarPanels
        # get toolbarPanel
        toolbarPanel = toolbarPanels.itemById(TOOLBAR_PANEL_ID)
        if not toolbarPanel:
            toolbarPanel = toolbarPanels.add(TOOLBAR_PANEL_ID, TOOLBAR_PANEL_NAME, 'SelectPanel', False)
        # create command definition
        commanDefinition = ui.commandDefinitions.itemById(MY_COMMAND_ID)
        if not commanDefinition:
            commanDefinition = ui.commandDefinitions.addButtonDefinition(MY_COMMAND_ID, MY_COMMAND_NAME, MY_COMMAND_TOOLTIP, "")
        # adds the commandDefinition to the toolbar panel
        cmdControl = toolbarPanel.controls.addCommand(commanDefinition)
        cmdControl.isPromotedByDefault = True
        onCommandTerminated = MyCommandTerminatedHandler()
        ui.commandTerminated.add(onCommandTerminated)
        handlers.append(onCommandTerminated)
        # add event handler
        onCommandCreated = CommandCreatedHandler()
        commanDefinition.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
    except:
def stop(context):
    try:
        # removes the panel from the toolbar
        workSpace = ui.workspaces.itemById('FusionSolidEnvironment')
        toolbarPanels = workSpace.toolbarPanels
        # get toolbarPanel
        if  toolbarPanel:
            toolbarPanel.deleteMe()
        # delete the commandDefinition
        commandDefinition = ui.commandDefinitions.itemById(MY_COMMAND_ID)
        if commandDefinition:
            commandDefinition.deleteMe()
        print("Addin stopped")
    except:
Replies (8)
Message 2 of 9
lichtzeichenanlage
Pull
Message 3 of 9
lichtzeichenanlage
Pull
Message 4 of 9
lichtzeichenanlage
Pull
Message 5 of 9
NDeis
I am also looking at understanding this event call better. Did you figure this out?
Message 6 of 9
lichtzeichenanlage
Nope. I haven't invested much time into it.
Message 7 of 9
OceanHydroAU
My guess is that's some kind of logic error - there's a reason for every call, and if you handle them all properly everything works nicely.
Message 8 of 9
NDeis
Ya the reason for the duplication is the question here.
From the logfile that my particular code generates I can confirm the onCommandStarting event trigger does seem to fire multiple times on most commands. Ie DrawPolyline, SketchStop, Extrude
I would like to understand if this is intentional or maybe this event is catching multiple types of interrupts.
Message 9 of 9
kandennti
Hi @lichtzeichenanlage .
I don't think it is possible to suppress the calls to the commandTerminated event.
On the other hand, if we are able to control the calls to it, I feel that it would be meaningless as an event.
Instead, I would check the args.commandId at the beginning of the Handler and return immediately if it is irrelevant.
    def __init__(self):
        super().__init__()
        try:
            global MY_COMMAND_ID
            if eventArgs.commandId != MY_COMMAND_ID:
                return
            global _document
            if _document:
                _document = None
        except:
            ui = adsk.core.Application.get().userInterface
However, this did not solve the issue of Fusion360 crashing.
