How to import file into Fusion 360 from web-server using Import Manager?
Message 1 of 8
Hello guys!
We are working on our project in the university and we faced some problems during the development process.
We are creating an add-in application that can import standard details and assemblies from web-server into Fusion 360 using Import Manager. Here's the code: (we want to import one 3D-model as test version), but the file is not selected. What might be the selected path?
app = adsk.core.Application.get()
ui = app.userInterface
importManager = app.importManager
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
rootComp = design.rootComponent
url = "http://195.133.144.86:4200//Half-coupling1.f3d"
archiveOptions = importManager.createFusionArchiveImportOptions(url)
importManager.importToTarget(archiveOptions)
Replies (7)
Message 2 of 8
BrianEkins
There is a problem with the API; either with the implementation or the documentation.  The documentation says you can provide a local filename or a URL but it looks like the implementation is only handling local files.  I don't know which one is wrong.  I would try and use just local files.  One way to do that is to have a local cache folder and if the file doesn't exist in the cache, then download it using something other than the Fusion API and then import it.  One simple method of downloading a file is to use curl.  It's included with the Mac OS and is small enough to package with the windows version of your program.  You can use the subprocess library or Python to run curl.
Brian Ekins
Message 3 of 8
kandennti
Hi @Anonymous .
It looked interesting, so I gave it a try.
I was able to import the file at that URL as a component.
# Fusion360API Python script
import adsk.core, adsk.fusion, traceback
import urllib.request
import urllib.error
import urllib.parse
import pathlib
def run(context):
    ui = None
    try:
        occ = importComponentFromURL(url)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# F3D File Only
def importComponentFromURL(url) -> adsk.fusion.Occurrence:
    # doc check
    doc :adsk.fusion.FusionDocument = app.activeDocument
    if not doc.dataFile:
        ui.messageBox('Please save the document once.')
        return adsk.fusion.Occurrence.cast(None)
    # get path
    folder = pathlib.Path(__file__).resolve().parent
    parsed = urllib.parse.urlparse(url)
    filename = parsed.path.split('//')[-1]
    dlFile = folder / filename
    # suffix check
    if dlFile.suffix != '.f3d':
        ui.messageBox('F3D File Only')
    # delete download file
    if dlFile.is_file():
        dlFile.unlink()
    # file download
    try:
        data = urllib.request.urlopen(url).read()
        with open(str(dlFile), mode="wb") as f:
            f.write(data)
    except:
        ui.messageBox(f'File not found in URL\n{url}')
    # import f3d
    app.executeTextCommand(f'Fusion.ImportComponent {str(dlFile)}')
    app.executeTextCommand(u'NuCommands.CommitCmd')
        dlFile.unlink()
    des = adsk.fusion.Design.cast(app.activeProduct)
    comp = des.activeComponent
    return comp.occurrences[-1]
When running the script, the active document needs to be saved once.
Message 4 of 8
Thank you so much for your answer, we do really appreciate that!
But could you please tell me how useful a couplings design system would be?
Message 5 of 8
Thank you so much for your answer!
Message 6 of 8
There's a problem anytime I try to run your script.
What might cause an error?
Message 7 of 8
BrianEkins
I'm not sure what a "couplings design system" is so I'm probably not the right person to answer your question.
Brian Ekins
Message 8 of 8
kandennti
@Anonymous .
In that sample, the f3d file is downloaded in the script's folder and imported.
Perhaps there is a problem with the path to the script folder. (PC login user name, etc.)
Please try to fix it here.
    # import f3d
    # app.executeTextCommand(f'Fusion.ImportComponent {str(dlFile)}')
    app.executeTextCommand(u'Fusion.ImportComponent {}'.format(dlFile))
If that doesn't work, try modifying it like this to force a folder to be created for the download.
    # get path
    # folder = pathlib.Path(__file__).resolve().parent
    folder = pathlib.Path(r'C:\Temp')
    if not folder.exists():
        folder.mkdir()
