How to get material of product on Fusion360?
ruban2
ruban2
Hello Everyone.
I am trying to get material of product on Fusion360.
what is api script for it?
kandennti
Hi @ruban2 .
"Product" was interpreted to mean occurrence or component.
The material name can be obtained in the following way
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui = core.UserInterface.cast(None)
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        for occ in root.allOccurrences:
            app.log(f'{occ.name} --> {occ.component.material.name}')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
However, if there are several bodies with different materials in one component, you will not get the correct result.
If you want to get the correct result, you need to refer to the material property of the body.
ruban2
Thank you for your message.
