How to get a OrientedBoundingBox3D from more faces?
maurizio_manzi
maurizio_manzi
with this code I get the OrientedBoundingBox3D of the first selected face (item 0).
But how can I get the OrientedBoundingBox3D of ALL the selected faces?
Best regards
Maurizio
brep_face = adsk.fusion.BRepFace.cast(ui.activeSelections.item(0).entity)
# Vector acquisition from eye direction. Just for test
        camera: core.Camera = app.activeViewport.camera
        vecLength: core.Vector3D = camera.eye.vectorTo(
            camera.target
        vecLength.normalize()
        vecWidth: core.Vector3D = vecLength.crossProduct(
            camera.upVector
        vecWidth.normalize()
measMgr: core.MeasureManager = app.measureManager
        orientedBBox: core.OrientedBoundingBox3D = measMgr.getOrientedBoundingBox(
            brep_face,
            vecLength,
            vecWidth,
kandennti
Hi @maurizio_manzi -san.
I created a temporary UnionBody.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        body: fusion.BRepBody = root.bRepBodies[0]
        # target faces
        faces = list(body.faces)[0:3]
            camera.target
            camera.upVector
        # OrientedBoundingBox
            create_union_body(faces),
            vecLength,
            vecWidth,
        # dump
        app.log("*********")
        app.log(f"CenterPoint:{orientedBBox.centerPoint.asArray()}")
        app.log(f"LengthDirection:{orientedBBox.lengthDirection.asArray()}")
        app.log(f"Length:{orientedBBox.length}")
        app.log(f"WidthDirection:{orientedBBox.widthDirection.asArray()}")
        app.log(f"Width:{orientedBBox.width}")
        app.log(f"HeightDirection:{orientedBBox.heightDirection.asArray()}")
        app.log(f"Height:{orientedBBox.height}")
        DumpBoundingBox(orientedBBox)
        ui.activeSelections.clear()
        [ui.activeSelections.add(f) for f in faces]
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def create_union_body(faces: list) -> fusion.BRepBody:
    if len(faces) < 1:
        return None
    tmpMgr: fusion.TemporaryBRepManager = fusion.TemporaryBRepManager.get()
    tmpBody: fusion.BRepBody = tmpMgr.copy(faces[0])
    if len(faces) < 2:
        return tmpBody
    for face in faces[1:]:
        tmpMgr.booleanOperation(
            tmpBody,
            tmpMgr.copy(face),
            fusion.BooleanTypes.UnionBooleanType,
    return tmpBody
def DumpBoundingBox(bBox: core.OrientedBoundingBox3D):
    tmpBody: fusion.BRepBody = tmpMgr.createBox(bBox)
    baseFeat: fusion.BaseFeature = None
    if des.designType == fusion.DesignTypes.ParametricDesignType:
        baseFeat = root.features.baseFeatures.add()
    bodies: fusion.BRepBodies = root.bRepBodies
    resBody: fusion.BRepBody = None
    if baseFeat:
        baseFeat.startEdit()
        try:
            bodies.add(tmpBody, baseFeat)
        except:
            pass
        finally:
            baseFeat.finishEdit()
            resBody = baseFeat.bodies[0]
    else:
        resBody = bodies.add(tmpBody)
    resBody.opacity = 0.5
maurizio_manzi
Thank you very much. This is very helpfull.
Best regards
Maurizio
