How to delete a cam operation ?
maurizio_manzi
maurizio_manzi
I can add a cam operation in a setup with:
operationInput = setup.operations.createInput('pocket2d')
op_2Dpocket = setup.operations.add(operationInput)
But how can I delete a cam operation from setup, that are no more needed ?
Best regards
Maurizio
kandennti
Hi @maurizio_manzi .
The Operation object did not have a deleteMe method, so I looked for another way.
Since there was a deleteEntities method in the Cam object, I thought I could delete it by doing the following, but I got an error.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.cam as cam
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        camObj: cam.CAM = app.activeProduct
        setup: cam.Setup = camObj.setups[0]
        ope: cam.Operation = setup.operations[0]
        objs: core.ObjectCollection = core.ObjectCollection.create()
        # objs.add([ope]) # NG
        objs.add(ope)
        # https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-3C5139A6-8639-4466-8DB5-008B721BC059
        camObj.deleteEntities(objs)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
I may be missing something, but the only thing I can think of is to set isSuppressed = True.
jeff.pek
The ability to delete an operation via the API is coming as of the next Fusion update, currently targeted at late May.
  Jeff
en9y37
Hi all!
The camObj.deleteEntities(objs) method doesn't work yet. This error message is thrown when it's executed:
      RuntimeError: 5 : API Function not yet implemented
Is there any other know method to delete several setups, manufacturing models or operations at once? I mean not iterating through all the setups, manufacturing models and operations.
Thanks in advance.
Jorge_Jaramillo
I tried to create a function that delete what camObj.deleteEntities(objs) should do and it worked.
You can use it meanwhile the deteleEntities() is implemented; after all, you can just replace it without any other changes.
It work with objects that have the deleteMe() method.
def test_delete_cam_oobject() -> None:
    def delete_cam_objects(oc: adsk.core.ObjectCollection) -> boolean:
        ret = True
        for obj in oc:
            try:
                ret |= obj.deleteMe()
            except:
                ret = False
        return(ret)
    cam: adsk.cam.CAM = doc.products.itemByProductType('CAMProductType')
    setup = cam.setups.item(0)
    operation = setup.operations.item(0)
    to_delete = adsk.core.ObjectCollection.create()
    to_delete.add(operation)
    to_delete.add(setup)
    app.log(f'{delete_cam_objects(to_delete)=}')
I hope this could help.
Jorge Jaramillo
