How to Debug C++ Code in Visual Studio with Break Points Memory?
tperam
tperam
How to Debug C++ Code  in Visual Studio with Break Points, Watch Window Memory Values?
Please Respond.
Thurai
goyals
May be you can try below steps.
1. Start Fusion
2. Build your add-in in Visual studio.
3. Attach the Fusion process with Visual studio using Debug->Attach to Process
4. Put the breakpoint in run method of your add-in
5. Run your add-in from Fusion Add-in dialog.
Please take a look at the help page in API documentation on this topic http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-ECC0A398-4D89-4776-A054-F7B432F7FCF6#Debuggin...
I hope it helps. Thanks.
Shyam Goyal
Sr. Software Dev. Manager
tperam
Thanks Goyals.
Thurai
tperam
Hi Goyals,
                I Followed the steps.
It Worked.
Thanks Goyals
LiveLover
Hello!
I follow these steps
but VS tells "The breakpoint will not currently be hit. No symbols have been loaded for this document."
I vary message text and I am sure that Fusion runs latest compiled Script project.
Any suggestions please!
