How to create selectionSet using the API?
sharas_s
Message 1 of 8
sharas_s
Hello everyone,
I am trying to create a Selection Set of a subcomponent sketch using API with `selectionSets.add()` but had no luck with it. Does anyone know how to make this method work? From the error message it seems this method requires 2 or 3 arguments instead of 1 or 2 mentioned in the documentation. Error message:
Example document structure for testing:
Code to reproduce the error:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        doc = app.activeDocument
        design = doc.products.item( 0 )
        for occ in design.rootComponent.occurrences:
            for sketch in occ.component.sketches:
                if 'XXXX' in sketch.name:
                    design.selectionSets.add(sketch, f'my_selection_set')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
I was able to solve this problem using commands but would like to know if there is a way using API:
cmdDefs: adsk.core.CommandDefinitions = ui.commandDefinitions
cmdDef: adsk.core.CommandDefinition = cmdDefs.itemById('CreateSelectionGroupCmd')
if cmdDef:
    cmdDef.execute()
Replies (7)
Message 2 of 8
Jorge_Jaramillo
Hi @sharas_s ,
From the SelectionSets specification it stands that the first parameter (entities) is an array.
So just enclose sketch in "[ ]" like so and you're done:
design.selectionSets.add([sketch], f'my_selection_set')
And if you need to include many more objects, just populate an array with all elements you want on the selection set and pass the array to the add method.
Hope this help.
Jorge
Message 3 of 8
sharas_s
Hey @Jorge_Jaramillo ,
Thank you for a response. Tried putting the sketch into a list but got another error:
Message 4 of 8
kandennti
@sharas_s .
I think I get errors in sketches other than the root component.
I thought it might be a Proxy issue, but I still get the error.
Message 5 of 8
kandennti
I have done such a test.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        des: adsk.fusion.Design = app.activeProduct
        des.designType = adsk.fusion.DesignTypes.ParametricDesignType
        root: adsk.fusion.Component = des.rootComponent
        # create body & sketch
        initDammy(root, 0)
        occ: adsk.fusion.Occurrence = root.occurrences.addNewComponent(
            adsk.core.Matrix3D.create()
        initDammy(occ.component, 2)
        # create SelectionSet
        # root
        initSelectionSet(root.bRepBodies[0])
        initSelectionSet(root.sketches[0])
        # occ
        initSelectionSet(occ.component.bRepBodies[0])
        initSelectionSet(occ.component.sketches[0])
        # proxy
        occ: adsk.fusion.Occurrence = root.occurrences[0]
        initSelectionSet(
            occ.component.bRepBodies[0].createForAssemblyContext(
                occ
        initSelectionSet(
            occ.component.sketches[0].createForAssemblyContext(
                occ
    except:
        if ui:
def initSelectionSet(
    entity: adsk.core.Base):
    if not hasattr(entity, 'parentComponent'):
        return
    comp: adsk.fusion.Component = entity.parentComponent
    des: adsk.fusion.Design = comp.parentDesign
    try:
        des.selectionSets.add(
            [entity],
            entity.name
    except:
        name = entity.name
        if entity.nativeObject:
            name = entity.nativeObject.name
        adsk.core.Application.get().log(
            f'Failed: {name}'
def initDammy(
    comp: adsk.fusion.Component,
    value: float) -> None:
    # body
    tmgMgr: adsk.fusion.TemporaryBRepManager = adsk.fusion.TemporaryBRepManager.get()
    tmpBody: adsk.fusion.BRepBody = tmgMgr.createSphere(
        adsk.core.Point3D.create(value, 0, 0),
        1
    baseFeat: adsk.fusion.BaseFeature = None
    baseFeat = comp.features.baseFeatures.add()
    bodies: adsk.fusion.BRepBodies = comp.bRepBodies
    baseFeat.startEdit()
    bodies.add(tmpBody, baseFeat)
    baseFeat.finishEdit()
    baseFeat.bodies[0].name = f'{comp.name}_{baseFeat.bodies[0].name}'
    # sketch
    skt: adsk.fusion.Sketch = comp.sketches.add(comp.xYConstructionPlane)
    skt.name = f'{comp.name}_{skt.name}'
    skt.sketchCurves.sketchCircles.addByCenterRadius(
        adsk.core.Point3D.create(value, 2, 0),
        1
Message 6 of 8
Jorge_Jaramillo
Hi @sharas_s ,
You missed the name of the selection set which is the second argument:
In this example I created 4 selections sets:
def createSelectionSets():
    try:
        des = adsk.fusion.Design.cast(app.activeProduct)
        sk = des.rootComponent.sketches.itemByName('xy1')
        lines = [skc for skc in sk.sketchCurves if skc.length<1]
        des.selectionSets.add(lines, 'instagram_curves_short')
        lines = [skc for skc in sk.sketchCurves if skc.length>=1]
        des.selectionSets.add(lines, 'instagram_curves_long')
        points = [skp for skp in sk.sketchPoints]
        des.selectionSets.add(points, 'instagram_points')
        disc = []
        ps = []
        for skcps in sk.sketchCurves.sketchControlPointSplines:
            if skcps.startSketchPoint.geometry.asArray() not in ps and \
               skcps.endSketchPoint.geometry.asArray not in ps:
                disc.append(skcps)
                ps.append(skcps.startSketchPoint.geometry.asArray())
                ps.append(skcps.endSketchPoint.geometry.asArray())
        des.selectionSets.add(disc, 'instagram_discontinuous')
    except:
        pass
This is the result:
Hope this help.
Jorge
Message 7 of 8
kandennti
It could be created by using the TextCommands.
import traceback
import adsk.fusion
import adsk.core
def run(context):
    try:
        initDammy(root, 0)
        # create SelectionSet - using textcommand
        # root
        initSelectionSet_TxtCmds(root.bRepBodies[0])
        initSelectionSet_TxtCmds(root.sketches[0])
        # occ
                occ
                occ
    except:
        if ui:
def initSelectionSet_TxtCmds(
        return
    ui: adsk.core.UserInterface = app.userInterface
    sels: adsk.core.Selections = ui.activeSelections
    sels.clear()
    sels.add(entity)
    beforeLst = [s for s in des.selectionSets]
    app.executeTextCommand('NuComponents.CreateSelectionGroupCmd')
    afterLst = [s for s in des.selectionSets]
    res = list(filter(lambda x: x not in beforeLst, afterLst))
    if len(res) < 1:
        return None
    selSet: adsk.core.SelectionSet = res[0]
    selSet.name = f'{entity.name}_TxtCmds'
    return selSet
def initDammy(
    # body
        1
    # sketch
        1
Message 8 of 8
sharas_s
Hey, thank you for your inputs.
@Jorge_Jaramillo your solutions works but only if sketches are in rootComponent. If they are within a subcomponent (as showed in original post), function doesn't work anymore, even if you use proxy as @kandennti mentioned.
@kandennti  solution using TextCommands seems the best option currently. Seems to work in all cases. At least until API function is fixed or explained better how to use it in such situations.
