How to create construction plane perpendicular to a line
maurizio_manzi
maurizio_manzi
I have a line:
line = sketch.sketchCurves.sketchLines.addByTwoPoints(startPoint, endPoint).
The line is slanted in space.
How can I create a construction plane at the "endPoint", perpendicular to the line?
Best regards
Maurizio
kandennti
Hi @maurizio_manzi -San.
How about something like this?
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        # sketch
        skt: fusion.Sketch = root.sketches.add(root.xYConstructionPlane)
        # points
        stPnt: fusion.SketchPoint = skt.sketchPoints.add(
                core.Point3D.create(1,2,3),
        edPnt: fusion.SketchPoint = skt.sketchPoints.add(
                core.Point3D.create(4,5,6),
        # line
        sktLine: fusion.SketchLine = skt.sketchCurves.sketchLines.addByTwoPoints(
            stPnt,
            edPnt,
        # plane
        planeIpt: fusion.ConstructionPlaneInput = root.constructionPlanes.createInput()
        planeIpt.setByDistanceOnPath(
            sktLine,
            core.ValueInput.createByReal(1),
        plane: fusion.ConstructionPlane = root.constructionPlanes.add(
            planeIpt,
        ui.messageBox("Done")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
maurizio_manzi
Thank you very much. It works fine!
