Hello!
I have a model, which relies on a set of curves, which I calculate in a script in Matlab.
When I build the model in Fusion I export it in CST Studio to run some simulations, then after analyzing it I apply some changes to the curves and build the new model.
For now I was doing in such way:
I have made a sketch, consisting the points, constrained each point using dimensions, and linked each dimension to user parameters. Then I have updated user parameters using the ParameterI/O AddIn.
It is a dumb way, required some time and efforts to constrain each point, but it worked very well for me.
Until the latest update... which killed lots of plugings and addins...
So the questions are:
is there a more efficient way then just manually click each point and apply dimension constrains?
Is there a way to maybe generate script from the sketch I have done manually to then do the same sketch using script?
The points coordinates has to be updated, not draw new ones, so the scripts like ImportSplineCSV won't do.
PS. Is there a chance that ParameterI/O will work again? Who is supporting it?
Cheers,
Oleg
