How to change parameters of assembly?
Message 1 of 1
Hi guys! I have a couple of questions about my programm for Fusion 360 API.
We made a system that uploads an assembly from web-server. Here you can see .py and html interface. We made lists with part parameters that are related to each other. User can choose necessary parameters to get right assembly. But the problem is that the system doesn't change the parameters of threads. I wanted to know if you might know how to solve that problem? (for example, if the diameter of rod is equal to 9, thread is equal to M9).
Coupling assembly is designed to transmit torque. The number of fixing holes and parts (nuts, bolts) is depend of the torque. I also have no idea how to change that parameter with code and bind that parameter with web-interface (html file).
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="UTF-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <link rel="stylesheet" href="css/style.css">
    <link href="https://cdn.jsdelivr.net/npm/bootstrap@5.0.0/dist/css/bootstrap.min.css" rel="stylesheet" integrity="sha384-wEmeIV1mKuiNpC+IOBjI7aAzPcEZeedi5yW5f2yOq55WWLwNGmvvx4Um1vskeMj0" crossorigin="anonymous">
<script src="https://cdn.jsdelivr.net/npm/bootstrap@5.0.0/dist/js/bootstrap.bundle.min.js" integrity="sha384-p34f1UUtsS3wqzfto5wAAmdvj+osOnFyQFpp4Ua3gs/ZVWx6oOypYoCJhGGScy+8" crossorigin="anonymous"></script>
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <title>Document</title>
</head>
<body>
    <div class="tabs">
        <input type="radio" name="inset" value="" id="tab_2" checked>
        <label for="tab_2">Муфта фланцевая</label>
        <div id="txt_2">
            <table>
                <tr>
                    <td>
                        <h3>
                            <b>Муфта фланцевая ГОСТ 20761-96</b>
                        </h3>
                        <p>
                            <b>Укажите исполнение:</b>
                        </p>
                        <p id="execution" >
                            <input type="radio" name="execution" value="short">для коротких концов валов <Br>
                            <input type="radio" name="execution" value="long" checked>для длинных концов валов <Br>
                        </p>
                        <hr class="hr-line">
                        <p><b>Укажите крутящий момент Mкр, Н*м </b></p>
                            <p>
                                <select name="torq" id="torq">
                                    <option selected value="16" >16.0</option>
                                    <option value="31.5">31.5</option>
                                    <option value="63">63.0</option>
                                    <option value="125">125.0</option>
                                    <option value="160">160.0</option>
                                    <option value="250">250.0</option>
                                    <option value="400">400.0</option>
                                    <option value ="630">600</option>
                                    <option value ="1000">1000</option>
                                    <option value="1600">1600</option>
                                    <option value="2500">2500</option>
                                    <option value="4000">4000</option>
                                    <option value="6300">6300</option>
                                    <option value="10000">10000</option>
                                    <option value="16000">16000</option>
                                    <option value="25000">25000</option>
                                    <option value="40000">40000</option>
                                </select>
                            </p>
                        <p><b>Диаметр посадочного отверстия d, мм:</b></p>
                        <p>
                            <select name="exct" id="key">
                                <option selected value="11" >11</option>
                                <option value="12">12</option>
                                <option value="14">14</option>
                                <option value="16">16</option>
                                <option value="18">18</option>
                                <option value="19">19</option>
                                <option value="20">20</option>
                                <option value="22">22</option>
                                <option value="24">24</option>
                                <option value="25">25</option>
                                <option value="28">28</option>
                                <option value="30">30</option>
                                <option value="32">32</option>
                                <option value="35">35</option>
                                <option value="36">36</option>
                                <option value="38">38</option>
                                <option value="40">40</option>
                                <option value="42">42</option>
                                <option value="45">45</option>
                                <option value="48">48</option>
                                <option value="50">50</option>
                            </select>
                        </p>
                    </td>
                    <td>
                        <p>
                            <img src="icons/flancDesign.png" class="fig">
                        </p>
                        <br>
                    </td>
                </tr>
                <tr class="bord">
                    <td class = "button-run">
                        <button class="run-button" id="Click" onclick=btnClick();>Применить</button>
                    </td>
                </tr>
            </table>
        </div>
    </div>
</body>
<script>
    function btnClick(){ //функция по нажатию на "Применить"
        var key = document.getElementById('key').value;
        //проверка выбранного конца вала, выбор исполнения
        var executions = document.getElementsByName('execution');
        var execution;
        for(var i = 0; i < executions.length; i++){
            if(executions[i].checked){
                execution = executions[i].value;
        //список метки и аргументов для py
        var sendStrJson = {
                action : "click",
                arguments : {key:key, execution:execution}
        adsk.fusionSendData('send', JSON.stringify(sendStrJson));
</script>
</html>
import adsk.core, adsk.fusion, adsk.cam, traceback
import urllib.request
import urllib.error
import urllib.parse
import pathlib
import json
handlers = []
app = adsk.core.Application.get()
ui  = app.userInterface
global execution
global num
def run(context):
    ui = None
    global num
    num = 0
    try:
        workSpace = ui.workspaces.itemById('FusionSolidEnvironment')
        tbPanels = workSpace.toolbarPanels
        tbPanel = tbPanels.itemById('NewPanel')
        if tbPanel:
            tbPanel.deleteMe()
        tbPanel = tbPanels.add('NewPanel', 'БИБЛИОТЕКА МУФТ', 'SelectPanel', False)
        cmdDef = ui.commandDefinitions.itemById('NewCommand')
        if cmdDef:
            cmdDef.deleteMe()
        cmdDef = ui.commandDefinitions.addButtonDefinition('NewCommand', 'Создать муфту', 'Ввод параметров для соединительных муфт','.//resource')
        tbPanel.controls.addCommand(cmdDef)
        # Запуск плагина
        sampleCommandCreated = SampleCommandCreatedEventHandler()
        cmdDef.commandCreated.add(sampleCommandCreated)
        handlers.append(sampleCommandCreated)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class SampleCommandCreatedEventHandler(adsk.core.CommandCreatedEventHandler): #Создание событий по нажатию на надстроку
    def __init__(self):
        super().__init__()
    def notify(self, args):
        eventArgs = adsk.core.CommandCreatedEventArgs.cast(args)
        cmd = eventArgs.command
        # Вызывает создание диалогового окна
        onExecute = SampleCommandExecuteHandler()
        cmd.execute.add(onExecute)
        handlers.append(onExecute)
        #Вызывает забирание детали из сервера, кидает в папку, из папки в проект, очищает папку
        onModel = SampleCommandCrateModelHandler()
        cmd.execute.add(onModel)
        handlers.append(onModel)
    # Подгружаем сборку муфты с сервера с предварительным сохранением в папке Temp
class SampleCommandCrateModelHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            product = app.activeProduct
            design = adsk.fusion.Design.cast(product)
            rootComp = design.rootComponent
            importManager = app.importManager
            # url = "http://195.133.144.86:4200//CouplingAssembly.f3d"
            # url = "http://195.133.144.86:4200//Couplingv2.f3d"
            url = "http://195.133.144.86:4200//CouplingAssemblyv5.f3d"
            doc = app.activeDocument
            if not doc.dataFile:
                ui.messageBox('Пожалуйста, закройте окно и сохраните документ!')
                # palette = None
                return adsk.fusion.Occurrence.cast(None)
            # создание папки для файла
            folder = pathlib.Path(r'C:\Temp')
            if not folder.exists():
                folder.mkdir()
            #задание имени для файла по имени на сервере
            parsed = urllib.parse.urlparse(url)
            filename = parsed.path.split('//')[-1]
            dlFile = folder / filename
            # провка расширения файла с сервера
            if dlFile.suffix != '.f3d':
                ui.messageBox('F3D File Only')
            # если файл если, то удалить
            if dlFile.is_file():
                dlFile.unlink()
            # загрузка файла
            try:
                data = urllib.request.urlopen(url).read()
                with open(str(dlFile), mode="wb") as f:
                    f.write(data)
            except:
                ui.messageBox(f'File not found in URL\n{url}')
            # импортирование
            archiveOptionsNew = importManager.createFusionArchiveImportOptions(str(dlFile))
            importManager.importToTarget(archiveOptionsNew, rootComp)
            # удаление скаченного файла
                dlFile.unlink()
        except:
            ui.messageBox('Command executed failed: {}'.format(traceback.format_exc()))
class SampleCommandExecuteHandler(adsk.core.CommandEventHandler): #создание диалогового окна и ожидание действия в HTML
    def __init__(self):
        super().__init__()
        try:
            palette = ui.palettes.itemById('myExport')
            if not palette:
                palette = ui.palettes.add('myExport', 'БИБЛИОТЕКА МУФТ', 'index.html', True, True, True, 750, 550)
                palette.dockingState = adsk.core.PaletteDockingStates.PaletteDockStateRight
                #должен быть запуск параметризации после нажатия на кнопку
                onHTMLEvent = MyHTMLEventHandler()
                palette.incomingFromHTML.add(onHTMLEvent)
                handlers.append(onHTMLEvent)
            else:
                palette.isVisible = True
        except:
class MyHTMLEventHandler(adsk.core.HTMLEventHandler): #По нажатию кнопки проверяется нажатое и меняются параметры у сборки
    def __init__(self):
        super().__init__()
        global execution
        global num
        # global
        try:
            design = app.activeProduct
            htmlArgs = adsk.core.HTMLEventArgs.cast(args)
            data = json.loads(htmlArgs.data)
            if data['action']=='clickOk':
                ui.messageBox('ok!')
                num += 1
                if palette :
                    palette.isVisible = False
            #если был клик, то забираем аргументы и проверяем выбранное исполнение
            if data['action']=='click':
                args = data['arguments']
                if args['execution'] == 'short': # для коротких концов валов
                    execution = '1'
                if args['execution'] == 'long': # для длинных концов валов
                    execution = '2'
                    #  параметризация для полумуфты 1
                    DHC, LHC, l1HC, l2HC, d2HC, d1HC, dHC, ext_all_HC, B_HC, H_HC, d3HC, d4HC, D2_HC, b1HC, b2HC, R1_HC, R_HC = 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
                    dataHC = [# Мкр = 16.0
                              ('80 mm', '25 mm', '8 mm', '2 mm', '25 mm', '11 mm', '18 mm', '1000 mm', '2 mm', '12.8 mm', '8 mm', '9 mm', '55 mm', '1 mm', '0.5 mm', '1 mm', '0.2 mm'),
                              ('80 mm', '32 mm', '8 mm', '2 mm', '25 mm', '12 mm', '20 mm', '1000 mm', '2 mm', '13.8 mm', '8 mm', '9 mm', '55 mm', '1 mm', '0.5 mm', '1 mm', '0.2 mm'),
                              ('80 mm', '32 mm', '8 mm', '2 mm', '25 mm', '14 mm', '22 mm', '1000 mm', '2.5 mm', '16.3 mm', '8 mm', '9 mm', '55 mm', '1 mm', '0.5 mm', '1 mm', '0.2 mm'),
                              ('80 mm', '42 mm', '8 mm', '2 mm', '25 mm', '16 mm', '25 mm', '1000 mm', '2.5 mm', '18.3 mm', '8 mm', '9 mm', '55 mm', '1 mm', '0.5 mm', '1 mm', '0.2 mm'),
                              ('80 mm', '42 mm', '8 mm', '2 mm', '25 mm', '18 mm', '28 mm', '1000 mm', '3 mm', '20.8 mm', '8 mm', '9 mm', '55 mm', '1 mm', '0.5 mm', '1 mm', '0.2 mm'),
                              # Мкр = 31.5
                              ('90 mm', '42 mm', '10 mm', '2 mm', '30 mm', '19 mm', '30 mm', '1000 mm', '3 mm', '21.8 mm', '8 mm', '9 mm', '60 mm', '1 mm', '0.5 mm', '1 mm', '0.2 mm'),
                              ('90 mm', '52 mm', '10 mm', '2 mm', '30 mm', '20 mm', '32 mm', '1000 mm', '3 mm', '22.8 mm', '8 mm', '9 mm', '60 mm', '1 mm', '0.5 mm', '1 mm', '0.2 mm'),
                              ('90 mm', '52 mm', '10 mm', '2 mm', '30 mm', '22 mm', '35 mm', '1000 mm', '3 mm', '24.8 mm', '8 mm', '9 mm', '60 mm', '1 mm', '0.5 mm', '1 mm', '0.2 mm'),
                              # Мкр = 63.0
                              ('100 mm', '52 mm', '12 mm', '2 mm', '40 mm', '24 mm', '38 mm', '1000 mm', '4 mm', '27.3 mm', '8 mm', '9 mm', '70 mm', '1 mm', '0.5 mm', '1 mm', '0.2 mm'),
                              ('100 mm', '62 mm', '12 mm', '2 mm', '40 mm', '25 mm', '40 mm', '1000 mm', '4 mm', '28.3 mm', '8 mm', '9 mm', '70 mm', '1 mm', '0.5 mm', '1 mm', '0.2 mm'),
                              ('100 mm', '62 mm', '12 mm', '2 mm', '40 mm', '28 mm', '42 mm', '1000 mm', '4 mm', '31.3 mm', '8 mm', '9 mm', '70 mm', '1 mm', '0.5 mm', '1 mm', '0.2 mm'),
                              # Мкр = 125.0
                              ('110 mm', '82 mm', '15 mm', '2 mm', '45 mm', '30 mm', '48 mm', '1000 mm', '4 mm', '33.8 mm', '10 mm', '11 mm', '80 mm', '1 mm', '0.5 mm', '1 mm', '0.2 mm'),
                              ('110 mm', '82 mm', '15 mm', '2 mm', '45 mm', '32 mm', '52 mm', '1000 mm', '5 mm', '35.8 mm', '10 mm', '11 mm', '80 mm', '1 mm', '0.5 mm', '1 mm', '0.4 mm'),
                              ('110 mm', '82 mm', '15 mm', '2 mm', '45 mm', '35 mm', '52 mm', '1000 mm', '5 mm', '38.8 mm', '10 mm', '11 mm', '80 mm', '1 mm', '0.5 mm', '1 mm', '0.4 mm'),
                              ('110 mm', '82 mm', '15 mm', '2 mm', '45 mm', '36 mm', '52 mm', '1000 mm', '5 mm', '39.8 mm', '10 mm', '11 mm', '80 mm', '1 mm', '0.5 mm', '1 mm', '0.4 mm'),
                              # Мкр = 160.0
                              ('120 mm', '82 mm', '16 mm', '2 mm', '50 mm', '38 mm', '56 mm', '1000 mm', '5 mm', '41.8 mm', '10 mm', '11 mm', '90 mm', '1 mm', '0.5 mm', '1 mm', '0.4 mm'),
                              # Мкр = 250.0
                              ('130 mm', '112 mm', '17 mm', '2 mm', '55 mm', '40 mm', '65 mm', '1000 mm', '5 mm', '44.4 mm', '10 mm', '11 mm', '100 mm', '1 mm', '0.5 mm', '1 mm', '0.4 mm'),
                              ('130 mm', '112 mm', '17 mm', '2 mm', '55 mm', '42 mm', '65 mm', '1000 mm', '5 mm', '46.4 mm', '10 mm', '11 mm', '100 mm', '1 mm', '0.5 mm', '1 mm', '0.4 mm'),
                              ('130 mm', '112 mm', '17 mm', '2 mm', '55 mm', '45 mm', '70 mm', '1000 mm', '5 mm', '49.9 mm', '10 mm', '11 mm', '100 mm', '1 mm', '0.5 mm', '1 mm', '0.4 mm'),
                              # Мкр = 400.0
                              ('140 mm', '112 mm', '17 mm', '2 mm', '65 mm', '48 mm', '75 mm', '1000 mm', '7 mm', '52.9 mm', '10 mm', '11 mm', '110 mm', '1.6 mm', '1 mm', '1 mm', '0.4 mm'),
                              ('140 mm', '112 mm', '17 mm', '2 mm', '65 mm', '50 mm', '75 mm', '1000 mm', '7 mm', '54.9 mm', '10 mm', '11 mm', '110 mm', '1.6 mm', '1 mm', '1 mm', '0.4 mm')]
                              # Мкр =
                              # Мкр =
                              # Мкр =
                              # Мкр =
                    keyParamHC = args['key'] +' mm'
                    ui.messageBox('ПОДТВЕРДИТЬ ДЕЙСТВИЕ')
                    for i in range(0, len(dataHC)):
                        if dataHC[i][5] == keyParamHC:
                            DHC = dataHC[i][0]
                            LHC = dataHC[i][1]
                            l1HC = dataHC[i][2]
                            l2HC = dataHC[i][3]
                            d2HC = dataHC[i][4]
                            d1HC = dataHC[i][5]
                            dHC = dataHC[i][6]
                            ext_all_HC = dataHC[i][7]
                            B_HC = dataHC[i][8]
                            H_HC = dataHC[i][9]
                            d3HC = dataHC[i][10]
                            d4HC = dataHC[i][11]
                            D2_HC = dataHC[i][12]
                            b1HC = dataHC[i][13]
                            b2HC = dataHC[i][14]
                            R1_HC = dataHC[i][15]
                            R_HC = dataHC[i][16]
                            break
                    if num == 0:
                        DHCParam = design.userParameters.itemByName('DHC')
                        DHCParam.expression = DHC
                        LHCParam = design.userParameters.itemByName('LHC')
                        LHCParam.expression = LHC
                        l_1HCParam = design.userParameters.itemByName('l1HC')
                        l_1HCParam.expression = l1HC
                        l_2HCParam = design.userParameters.itemByName('l2HC')
                        l_2HCParam.expression = l2HC
                        d_1HCParam = design.userParameters.itemByName('d1HC')
                        d_1HCParam.expression = d1HC
                        dHCParam = design.userParameters.itemByName('dHC')
                        dHCParam.expression = dHC
                        d_2HCParam = design.userParameters.itemByName('d2HC')
                        d_2HCParam.expression = d2HC
                        extHCParam = design.userParameters.itemByName('ext_all_HC')
                        extHCParam.expression = ext_all_HC
                        BHCParam = design.userParameters.itemByName('B_HC')
                        BHCParam.expression = B_HC
                        H_HCParam = design.userParameters.itemByName('H_HC')
                        H_HCParam.expression = H_HC
                        d_3HCParam = design.userParameters.itemByName('d3HC')
                        d_3HCParam.expression = d3HC
                        d_4HCParam = design.userParameters.itemByName('d4HC')
                        d_4HCParam.expression = d4HC
                        D_2HCParam = design.userParameters.itemByName('D2_HC')
                        D_2HCParam.expression = D2_HC
                        b_1HCParam = design.userParameters.itemByName('b1HC')
                        b_1HCParam.expression = b1HC
                        b_2HCParam = design.userParameters.itemByName('b2HC')
                        b_2HCParam.expression = b2HC
                        R_1HCParam = design.userParameters.itemByName('R1_HC')
                        R_1HCParam.expression = R1_HC
                        R_HCParam = design.userParameters.itemByName('R_HC')
                        R_HCParam.expression = R_HC
                    elif num != 0:
                        DHCParam = design.userParameters.itemByName('DHC' + '_' + str(num))
                        LHCParam = design.userParameters.itemByName('LHC' + '_' + str(num))
                        l_1HCParam = design.userParameters.itemByName('l1HC' + '_' + str(num))
                        l_2HCParam = design.userParameters.itemByName('l2HC' + '_' + str(num))
                        d_1HCParam = design.userParameters.itemByName('d1HC' + '_' + str(num))
                        dHCParam = design.userParameters.itemByName('dHC' + '_' + str(num))
                        d_2HCParam = design.userParameters.itemByName('d2HC' + '_' + str(num))
                        extHCParam = design.userParameters.itemByName('ext_all_HC' + '_' + str(num))
                        BHCParam = design.userParameters.itemByName('B_HC' + '_' + str(num))
                        H_HCParam = design.userParameters.itemByName('H_HC' + '_' + str(num))
                        d_3HCParam = design.userParameters.itemByName('d3HC' + '_' + str(num))
                        d_4HCParam = design.userParameters.itemByName('d4HC' + '_' + str(num))
                        D_2HCParam = design.userParameters.itemByName('D2_HC' + '_' + str(num))
                        b_1HCParam = design.userParameters.itemByName('b1HC' + '_' + str(num))
                        b_2HCParam = design.userParameters.itemByName('b2HC' + '_' + str(num))
                        R_1HCParam = design.userParameters.itemByName('R1_HC' + '_' + str(num))
                        R_HCParam = design.userParameters.itemByName('R_HC' + '_' + str(num))
                    DHC2, LHC2, l1_HC2, l2_HC2, d2_HC2, d1_HC2, dHC2, ext_all_HC2, B_HC2, H_HC2, d3HC2, d4HC2, D2_HC2, b1_HC2, b2_HC2, R1_HC2, R_HC2 = 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
                    dataHC2 = [# Мкр = 16.0
                              # Мкр = 31.5
                              # Мкр = 63.0
                              # Мкр = 125.0
                              # Мкр = 160.0
                              # Мкр = 250.0
                              # Мкр = 400.0
                    # keyParamHC = args['key'] +' mm'
                    # ui.messageBox('ПОДТВЕРДИТЬ ДЕЙСТВИЕ')
                    for i in range(0, len(dataHC2)):
                        if dataHC2[i][5] == keyParamHC:
                            DHC2 = dataHC2[i][0]
                            LHC2 = dataHC2[i][1]
                            l1_HC2 = dataHC2[i][2]
                            l2_HC2 = dataHC2[i][3]
                            d2_HC2 = dataHC2[i][4]
                            d1_HC2 = dataHC2[i][5]
                            dHC2 = dataHC2[i][6]
                            ext_all_HC2 = dataHC2[i][7]
                            B_HC2 = dataHC2[i][8]
                            H_HC2 = dataHC2[i][9]
                            d3HC2 = dataHC2[i][10]
                            d4HC2 = dataHC2[i][11]
                            D2_HC2 = dataHC2[i][12]
                            b1_HC2 = dataHC2[i][13]
                            b2_HC2 = dataHC2[i][14]
                            R1_HC2 = dataHC2[i][15]
                            R_HC2 = dataHC2[i][16]
                            break
                    if num == 0:
                        DHCParam2 = design.userParameters.itemByName('DHC2')
                        DHCParam2.expression = DHC2
                        LHCParam2 = design.userParameters.itemByName('LHC2')
                        LHCParam2.expression = LHC2
                        l_1HCParam2 = design.userParameters.itemByName('l1_HC2')
                        l_1HCParam2.expression = l1_HC2
                        l_2HCParam2 = design.userParameters.itemByName('l2_HC2')
                        l_2HCParam2.expression = l2_HC2
                        d_1HCParam2 = design.userParameters.itemByName('d1_HC2')
                        d_1HCParam2.expression = d1_HC2
                        dHCParam2 = design.userParameters.itemByName('dHC2')
                        dHCParam2.expression = dHC2
                        d_2HCParam2 = design.userParameters.itemByName('d2_HC2')
                        d_2HCParam2.expression = d2_HC2
                        extHCParam2 = design.userParameters.itemByName('ext_all_HC2')
                        extHCParam2.expression = ext_all_HC2
                        BHCParam2 = design.userParameters.itemByName('B_HC2')
                        BHCParam2.expression = B_HC2
                        H_HCParam2 = design.userParameters.itemByName('H_HC2')
                        H_HCParam2.expression = H_HC2
                        d_3HCParam2 = design.userParameters.itemByName('d3HC2')
                        d_3HCParam2.expression = d3HC2
                        d_4HCParam2 = design.userParameters.itemByName('d4HC2')
                        d_4HCParam2.expression = d4HC2
                        D_2HCParam2 = design.userParameters.itemByName('D2_HC2')
                        D_2HCParam2.expression = D2_HC2
                        b_1HCParam2 = design.userParameters.itemByName('b1_HC2')
                        b_1HCParam2.expression = b1_HC2
                        b_2HCParam2 = design.userParameters.itemByName('b2_HC2')
                        b_2HCParam2.expression = b2HC
                        R_1HCParam2 = design.userParameters.itemByName('R1_HC2')
                        R_1HCParam2.expression = R1_HC2
                        R_HCParam2 = design.userParameters.itemByName('R_HC2')
                        R_HCParam2.expression = R_HC2
                    elif num != 0:
                        DHCParam2 = design.userParameters.itemByName('DHC2' + '_' + str(num))
                        LHCParam2 = design.userParameters.itemByName('LHC2' + '_' + str(num))
                        l_1HCParam2 = design.userParameters.itemByName('l1_HC2' + '_' + str(num))
                        l_2HCParam2 = design.userParameters.itemByName('l2_HC2' + '_' + str(num))
                        d_1HCParam2 = design.userParameters.itemByName('d1_HC2' + '_' + str(num))
                        dHCParam2 = design.userParameters.itemByName('dHC2' + '_' + str(num))
                        d_2HCParam2 = design.userParameters.itemByName('d2_HC2' + '_' + str(num))
                        extHCParam2 = design.userParameters.itemByName('ext_all_HC2' + '_' + str(num))
                        BHCParam2 = design.userParameters.itemByName('B_HC2' + '_' + str(num))
                        H_HCParam2 = design.userParameters.itemByName('H_HC2' + '_' + str(num))
                        d_3HCParam2 = design.userParameters.itemByName('d3HC2' + '_' + str(num))
                        d_4HCParam2 = design.userParameters.itemByName('d4HC2' + '_' + str(num))
                        D_2HCParam2 = design.userParameters.itemByName('D2_HC2' + '_' + str(num))
                        b_1HCParam2 = design.userParameters.itemByName('b1_HC2' + '_' + str(num))
                        b_2HCParam2 = design.userParameters.itemByName('b2_HC2' + '_' + str(num))
                        R_1HCParam2 = design.userParameters.itemByName('R1_HC2' + '_' + str(num))
                        R_HCParam2 = design.userParameters.itemByName('R_HC2' + '_' + str(num))
                    # Параметризация болта ГОСТ 7817
                    dataBolt78 = [('12 mm', '5.5 mm', '35 mm', '29.5 mm', '22.5 mm', '8 mm', '9 mm', '0.4 mm', '1 mm', '5.3 mm', '2 mm', '100 mm'),
                                  ('12 mm', '5.5 mm', '40 mm', '34 mm', '24.5 mm', '8 mm', '9 mm', '0.4 mm', '1 mm', '5.3 mm', '2 mm', '100 mm'),
                                  ('14 mm', '7 mm', '45 mm', '39.5 mm', '27 mm', '10 mm', '11 mm', '0.4 mm', '2.5 mm', '6.7 mm', '2.5 mm', '100 mm'),
                                  ('14 mm', '7 mm', '50 mm', '44.5 mm', '32 mm', '10 mm', '11 mm', '0.4 mm', '2.5 mm', '6.7 mm', '2.5 mm', '100 mm'),
                                  ('17 mm', '8 mm', '60 mm', '53 mm', '40 mm', '12 mm', '13 mm', '0.6 mm', '3.2 mm', '8.1 mm', '3.2 mm', '100 mm'),
                                  ('17 mm', '8 mm', '65 mm', '58 mm', '45 mm', '12 mm', '13 mm', '0.6 mm', '3.2 mm', '8.1 mm', '3.2 mm', '100 mm'),
                                  ('17 mm', '8 mm', '70 mm', '63 mm', '50 mm', '12 mm', '13 mm', '0.6 mm', '3.2 mm', '8.1 mm', '3.2 mm', '100 mm'),
                                  ('22 mm', '12 mm', '80 mm', '71 mm', '53 mm', '16 mm', '17 mm', '0.6 mm', '4 mm', '11.1 mm', '4 mm', '100 mm'),
                                  ('27 mm', '13 mm', '90 mm', '80 mm', '60 mm', '20 mm', '21 mm', '0.8 mm', '4 mm', '13.8 mm', '4 mm', '100 mm'),
                                  ('27 mm', '13 mm', '100 mm', '90 mm', '70 mm', '20 mm', '21 mm', '0.8 mm', '4 mm', '13.8 mm', '4 mm', '100 mm'),
                                  ('32 mm', '15 mm', '110 mm', '99 mm', '67 mm', '24 mm', '25 mm', '0.8 mm', '5 mm', '16.6 mm', '5', '100 mm'),
                                  ('32 mm', '15 mm', '120 mm', '109 mm', '77 mm', '24 mm', '25 mm', '0.8 mm', '5 mm', '16.6 mm', '5', '100 mm')]
                    keyParamBolt78 = d4HC
                    for i in range(0, len(dataBolt78)):
                        if dataBolt78[i][6] == keyParamBolt78:
                            S_bolt78 = dataBolt78[i][0]
                            m_bolt78 = dataBolt78[i][1]
                            L_bolt78 = dataBolt78[i][2]
                            l1_bolt78 = dataBolt78[i][3]
                            l2_bolt78 = dataBolt78[i][4]
                            d_bolt78 = dataBolt78[i][5]
                            d1_bolt78 = dataBolt78[i][6]
                            R_bolt78 = dataBolt78[i][7]
                            l3_bolt78 = dataBolt78[i][8]
                            d3_bolt78 = dataBolt78[i][9]
                            d4_bolt78 = dataBolt78[i][10]
                            ext_all_bolt = dataBolt78[i][11]
                            break
                    if num == 0:
                        S_boltParam = design.userParameters.itemByName('S_bolt78')
                        S_boltParam.expression = S_bolt78
                        m_BoltParam = design.userParameters.itemByName('m_bolt78')
                        m_BoltParam.expression = m_bolt78
                        LBoltParam = design.userParameters.itemByName('L_bolt78')
                        LBoltParam.expression = L_bolt78
                        l_1BoltParam = design.userParameters.itemByName('l1_bolt78')
                        l_1BoltParam.expression = l1_bolt78
                        l_2BoltParam = design.userParameters.itemByName('l2_bolt78')
                        l_2BoltParam.expression = l2_bolt78
                        dBoltParam = design.userParameters.itemByName('d_bolt78')
                        dBoltParam.expression = d_bolt78
                        d_1BoltParam = design.userParameters.itemByName('d1_bolt78')
                        d_1BoltParam.expression = d1_bolt78
                        R_BoltParam = design.userParameters.itemByName('R_bolt78')
                        R_BoltParam.expression = R_bolt78
                        l_3BoltParam = design.userParameters.itemByName('l3_bolt78')
                        l_3BoltParam.expression = l3_bolt78
                        d_3BoltParam = design.userParameters.itemByName('d3_bolt78')
                        d_3BoltParam.expression = d3_bolt78
                        d_4BoltParam = design.userParameters.itemByName('d4_bolt78')
                        d_4BoltParam.expression = d4_bolt78
                        ext_allBoltParam = design.userParameters.itemByName('ext_all_bolt')
                        ext_allBoltParam.expression = ext_all_bolt
                    elif num != 0:
                        S_boltParam = design.userParameters.itemByName('S_bolt78' + '_' + str(num))
                        m_BoltParam = design.userParameters.itemByName('m_bolt78' + '_' + str(num))
                        LBoltParam = design.userParameters.itemByName('L_bolt78' + '_' + str(num))
                        l_1BoltParam = design.userParameters.itemByName('l1_bolt78' + '_' + str(num))
                        l_2BoltParam = design.userParameters.itemByName('l2_bolt78' + '_' + str(num))
                        dBoltParam = design.userParameters.itemByName('d_bolt78' + '_' + str(num))
                        d_1BoltParam = design.userParameters.itemByName('d1_bolt78' + '_' + str(num))
                        R_BoltParam = design.userParameters.itemByName('R_bolt78' + '_' + str(num))
                        l_3BoltParam = design.userParameters.itemByName('l3_bolt78' + '_' + str(num))
                        d_3BoltParam = design.userParameters.itemByName('d3_bolt78' + '_' + str(num))
                        d_4BoltParam = design.userParameters.itemByName('d4_bolt78' + '_' + str(num))
                        ext_allBoltParam = design.userParameters.itemByName('ext_all_bolt' + '_' + str(num))
                  # Параметризация для болта ГОСТ 7796
                    S_bolt77 = 0
                    d_bolt77 = 0
                    m_bolt77 = 0
                    D_bolt77 = 0
                    R_bolt77 = 0
                    l1_bolt77 = 0
                    b_bolt77 = 0
                    chm_bolt77 = 0
                    # thr_bolt2 = 0
                    dataBolt77 = [('12 mm', '8 mm', '5 mm', '5.718 mm', '30 mm', '0.2 mm', '22 mm', '0.8 mm'),
                                  ('12 mm', '8 mm', '5 mm', '5.718 mm', '0.1 mm', '0.2 mm','35 mm', '22 mm', '0.8 mm'),
                                  ('12 mm', '8 mm', '5 mm', '5.718 mm', '0.1 mm', '0.2 mm','40 mm', '22 mm', '0.8 mm'),
                                  ('14 mm', '10 mm', '6 mm', '6.7 mm', '0.1 mm', '0.2 mm', '45 mm', '26 mm', '0.92 mm'),
                                  ('14 mm', '10 mm', '6 mm', '6.7 mm', '50 mm', '0.2 mm','26 mm', '0.92 mm'),
                                  ('17 mm', '12 mm', '7 mm', '8.1 mm', '60 mm','0.2 mm', '30 mm', '1 mm'),
                                  ('17 mm', '12 mm', '7 mm', '8.1 mm', '65 mm', '0.2 mm','30 mm', '1 mm'),
                                  ('17 mm', '12 mm', '7 mm', '8.1 mm', '70 mm', '0.2 mm','30 mm', '1 mm'),
                                  ('22 mm', '16 mm', '8 mm', '10.5 mm', '80 mm', '0.2 mm','38 mm', '1.3 mm'),
                                  ('27 mm', '20 mm', '11 mm', '12.9 mm', '90 mm', '0.2 mm','46 mm', '1.5 mm'),
                                  ('27 mm', '20 mm', '11 mm', '12.9 mm', '100 mm', '0.2 mm','46 mm', '1.5 mm'),
                                  ('32 mm', '24 mm', '13 mm', '15.3 mm', '110 mm', '0.2 mm','54 mm', '1.8 mm'),
                                  ('32 mm', '24 mm', '13 mm', '15.3 mm', '120 mm', '0.2 mm', '54 mm', '1.8 mm')]
                    keyParamBolt77 = d3HC
                    for i in range(0, len(dataBolt77)):
                        if dataBolt77[i][1] == keyParamBolt77:
                            S_bolt77 = dataBolt77[i][0]
                            d_bolt77 = dataBolt77[i][1]
                            m_bolt77 = dataBolt77[i][2]
                            D_bolt77 = dataBolt77[i][3]
                            R_bolt77 = dataBolt77[i][4]
                            l1_bolt77 = dataBolt77[i][5]
                            b_bolt77 = dataBolt77[i][6]
                            chm_bolt77 = dataBolt77[i][7]
                            break
                    if num == 0:
                        S_bolt2Param = design.userParameters.itemByName('S_bolt77')
                        S_bolt2Param.expression = S_bolt77
                        dB2Param = design.userParameters.itemByName('d_bolt77')
                        dB2Param.expression = d_bolt77
                        m_B2Param = design.userParameters.itemByName('m_bolt77')
                        m_B2Param.expression = m_bolt77
                        D_B2Param = design.userParameters.itemByName('D_bolt77')
                        D_B2Param.expression = D_bolt77
                        R_Bolt2Param = design.userParameters.itemByName('R_bolt77')
                        R_Bolt2Param.expression = R_bolt77
                        l_1B2Param = design.userParameters.itemByName('l1_bolt77')
                        l_1B2Param.expression = l1_bolt77
                        bB2Param = design.userParameters.itemByName('b_bolt77')
                        bB2Param.expression = b_bolt77
                        chmB2Param = design.userParameters.itemByName('chm_bolt77')
                        chmB2Param.expression = chm_bolt77
                    if num != 0:
                        S_bolt2Param = design.userParameters.itemByName('S_bolt77' + '_' + str(num))
                        dB2Param = design.userParameters.itemByName('d_bolt77' + '_' + str(num))
                        m_B2Param = design.userParameters.itemByName('m_bolt77' + '_' + str(num))
                        D_B2Param = design.userParameters.itemByName('D_bolt77' + '_' + str(num))
                        R_Bolt2Param = design.userParameters.itemByName('R_bolt77' + '_' + str(num))
                        l_1B2Param = design.userParameters.itemByName('l1_bolt77' + '_' + str(num))
                        bB2Param = design.userParameters.itemByName('b_bolt77' + '_' + str(num))
                        chmB2Param = design.userParameters.itemByName('chm_bolt77' + '_' + str(num))
                    # Параметризация гайки 1
                    S_nut = 0
                    d_nut = 0
                    k_nut = 0
                    ch_nut = 0
                    dataNut = [('12 mm', '8 mm', '6.5 mm', '0.4 mm'),
                               ('14 mm', '10 mm', '8 mm', '0.5 mm'),
                               ('17 mm', '12 mm', '10 mm', '0.55 mm'),
                               ('22 mm', '16 mm', '13 mm', '0.625 mm'),
                               ('27 mm', '20 mm', '16 mm', '0.78 mm'),
                               ('32 mm', '24 mm', '19 mm', '0.94 mm')]
                    keyParamNut = d_bolt78
                    for i in range(0, len(dataNut)):
                        if dataNut[i][1] == keyParamNut:
                            S_nut = dataNut[i][0]
                            d_nut = dataNut[i][1]
                            k_nut = dataNut[i][2]
                            ch_nut = dataNut[i][3]
                            break
                    if num == 0:
                        S_nutParam = design.userParameters.itemByName('S_nut')
                        S_nutParam.expression = S_nut
                        dNutParam = design.userParameters.itemByName('d_nut')
                        dNutParam.expression = d_nut
                        kNutParam = design.userParameters.itemByName('k_nut')
                        kNutParam.expression = k_nut
                        chNutParam = design.userParameters.itemByName('ch_nut')
                        chNutParam.expression = ch_nut
                    elif num != 0:
                        S_nutParam = design.userParameters.itemByName('S_nut' + str(num))
                        dNutParam = design.userParameters.itemByName('d_nut' + str(num))
                        kNutParam = design.userParameters.itemByName('k_nut' + str(num))
                        chNutParam = design.userParameters.itemByName('ch_nut' + str(num))
                   # Параметризация гайки 2
                    S_nut2 = 0
                    d_nut2 = 0
                    k_nut2 = 0
                    ch_nut2 = 0
                    dataNut2 = [('12 mm', '8 mm', '6.5 mm', '0.4 mm'),
                    keyParamNut2 = d_bolt77
                        if dataNut2[i][1] == keyParamNut2:
                            S_nut2 = dataNut2[i][0]
                            d_nut2 = dataNut2[i][1]
                            k_nut2 = dataNut2[i][2]
                            ch_nut2 = dataNut2[i][3]
                            break
                    if num == 0:
                        S_nutParam_1 = design.userParameters.itemByName('S_nut2')
                        S_nutParam_1.expression = S_nut2
                        dNutParam_1 = design.userParameters.itemByName('d_nut2')
                        dNutParam_1.expression = d_nut2
                        kNutParam_1 = design.userParameters.itemByName('k_nut2')
                        kNutParam_1.expression = k_nut2
                        chNutParam_1 = design.userParameters.itemByName('ch_nut2')
                        chNutParam_1.expression = ch_nut2
                    elif num != 0:
                        S_nutParam_1 = design.userParameters.itemByName('S_nut2' + '_' + str(num))
                        dNutParam_1 = design.userParameters.itemByName('d_nut2' + '_' + str(num))
                        kNutParam_1 = design.userParameters.itemByName('k_nut2' + '_' + str(num))
                        chNutParam_1 = design.userParameters.itemByName('ch_nut2' + '_' + str(num))
                     # Параметризация шайбы 1
                    d_ws = 0
                    b_ws = 0
                    Dws = 0
                    Sws = 0
                    # angle_ws = 0
                    ext_ws = 0
                    dataWs = [('8 mm', '2 mm', '10.2 mm', '1.6 mm', '100 mm'),
                              ('10 mm', '2.5 mm', '12.7 mm', '2 mm', '100 mm'),
                              ('12 mm', '3.5 mm', '15.7 mm', '2.5 mm', '100 mm'),
                              ('16 mm', '4.5 mm', '20.8 mm', '3.5 mm', '100 mm'),
                              ('20 mm', '5.5 mm','26 mm', '4.5 mm', '100 mm'),
                              ('24 mm','6.5 mm', '31 mm', '5.5 mm', '100 mm')]
                    keyParamWs = d_bolt77
                    for i in range(0, len(dataWs)):
                        if dataWs[i][0] == keyParamWs:
                            d_ws = dataWs[i][0]
                            b_ws = dataWs[i][1]
                            Dws = dataWs[i][2]
                            Sws = dataWs[i][3]
                            # angle_ws = dataWs[i][4]
                            ext_ws = dataWs[i][4]
                            break
                    if num == 0:
                        dParam = design.userParameters.itemByName('d_ws')
                        dParam.expression = d_ws
                        bParam = design.userParameters.itemByName('b_ws')
                        bParam.expression = b_ws
                        DParam = design.userParameters.itemByName('Dws')
                        DParam.expression = Dws
                        S_Param = design.userParameters.itemByName('Sws')
                        S_Param.expression = Sws
                        # angleParam = design.userParameters.itemByName('angle')
                        # angleParam.expression = angle_ws
                        ext_WParam = design.userParameters.itemByName('ext_ws')
                        ext_WParam.expression = ext_ws
                    elif num != 0:
                        dParam = design.userParameters.itemByName('d_ws' + '_' + str(num))
                        bParam = design.userParameters.itemByName('b_ws' + '_' + str(num))
                        DParam = design.userParameters.itemByName('Dws' + '_' + str(num))
                        S_Param = design.userParameters.itemByName('Sws' + '_' + str(num))
                        # angleParam = design.userParameters.itemByName('angle' + '_' + str(num))
                        ext_WParam = design.userParameters.itemByName('ext_ws' + '_' + str(num))
                    # Параметризация шайбы 2
                    d_ws2 = 0
                    b_ws2 = 0
                    D_ws2 = 0
                    Sws2 = 0
                    # angle_ws2 = 0
                    ext_ws2 = 0
                    dataWs2 = [('8 mm', '2 mm', '10.2 mm', '1.6 mm', '1000 mm'),
                              ('10 mm', '2.5 mm', '12.7 mm', '2 mm', '1000 mm'),
                              ('12 mm', '3.5 mm', '15.7 mm', '2.5 mm', '1000 mm'),
                              ('16 mm', '4.5 mm', '20.8 mm', '3.5 mm', '1000 mm'),
                              ('20 mm', '5.5 mm','26 mm', '4.5 mm', '1000 mm'),
                              ('24 mm','6.5 mm', '31 mm', '5.5 mm','1000 mm')]
                    keyParamWs2 = d_bolt78
                    for i in range(0, len(dataWs2)):
                        if dataWs2[i][0] == keyParamWs2:
                            d_ws2 = dataWs2[i][0]
                            b_ws2 = dataWs2[i][1]
                            D_ws2 = dataWs2[i][2]
                            Sws2 = dataWs2[i][3]
                            # angle_ws2 = dataWs2[i][4]
                            ext_ws2 = dataWs2[i][4]
                            break
                    if num == 0:
                        dParam = design.userParameters.itemByName('d_ws2')
                        dParam.expression = d_ws2
                        bParam = design.userParameters.itemByName('b_ws2')
                        bParam.expression = b_ws2
                        DParam = design.userParameters.itemByName('D_ws2')
                        DParam.expression = D_ws2
                        S_Param = design.userParameters.itemByName('Sws2')
                        S_Param.expression = Sws2
                        # angleParam = design.userParameters.itemByName('angle2')
                        # angleParam.expression = angle_ws2
                        ext_WParam.expression = ext_ws2
                    elif num != 0:
                        dParam = design.userParameters.itemByName('d_ws2' + '_' + str(num))
                        bParam = design.userParameters.itemByName('b_ws2' + '_' + str(num))
                        DParam = design.userParameters.itemByName('D_ws2' + '_' + str(num))
                        S_Param = design.userParameters.itemByName('Sws2' + '_' + str(num))
                        # angleParam = design.userParameters.itemByName('angle2' + '_' + str(num))
        except:
            if ui:
def stop(context):
    ui = None
    try:
        if tbPanel:
            tbPanel.deleteMe()
        if palette:
            palette.deleteMe()
    except:
        if ui:
Replies (0)
