How do I change isSmoothTransition for named view?
soswow
soswow
1. Create named view called `view1`
Open python console and execute:
app = adsk.core.Application.get()
app.activeProduct.namedViews.itemByName("view1").camera.isSmoothTransition # -> True
cam = app.activeProduct.namedViews.itemByName("view1").camera
cam.isSmoothTransition = False
cam.isSmoothTransition # -> False
app.activeProduct.namedViews.itemByName("view1").camera = cam
app.activeProduct.namedViews.itemByName("view1").camera.isSmoothTransition # -> True (Still)
BrianEkins
I don't think named views let you control whether they have a smooth transition. I don't see an option for that in the UI. The fact that the API uses a Camera object to define a named view doesn't mean that the named view uses all of the settings on a Camera.
There is a workaround if you don't want a smooth transition when applying a named view. Instead of applying the named view, you can get the camera from the named view. Turn off the smooth transition and then set the camera for the active viewport using that camera.
Brian Ekins
