How can create a patch by a loop
ho-kou
ho-kou
Hi everybody,
I want to create a patch using the loop inside Fig.1 and Fig.2 according to the following flow.
①Gets all loops for each face of the target body.
②If the loop obtained in ① has an internal shape, use this loop to create a sketch.
③Create a patch using the sketch profile created in ②.
Issue: Depending on the shape of the internal loop, the sketch profile for patch creation may not be generated.
For example, [sample_a.step] is NG. [Sample_b.step] is OK.
Can you tell me how to create a patch even with the shape of [sample_a.step]?
# Assuming you have not changed the general structure of the template no modification is needed in this file.
from . import commands
from .lib import fusion360utils as futil
import adsk.core, adsk.fusion, adsk.cam, traceback
_app = None
_ui  = None
_design = None
_rootComp = None
def run(context):
    try:
        # This will run the start function in each of your commands as defined in commands/__init__.py
        commands.start()
        # fusion情報を取得
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui  = _app.userInterface
        product = _app.activeProduct
        global _design
        _design = adsk.fusion.Design.cast(product)
        global _rootComp
        _rootComp = _design.rootComponent
        allBodies = _rootComp.bRepBodies
        bodycount = allBodies.count
        if allBodies.count < 1:
            _ui.messageBox('Body count is not exist')
            return
        newbody = allBodies.item(0)
        # create patch
        oresult = [-1]
        CreatePatch(newbody, oresult)
        return
    except:
        futil.handle_error('run')
# create patch
def CreatePatch(targetbody,
                oresult):
    try:
        oresult[0] = -1
        i = 0
        j = 0
        for face in targetbody.faces:
            for Loop in face.loops:
                if Loop.isOuter:
                    # if Loop is Outer
                    continue
                # create sketch by inter loop
                brepEdges = Loop.edges
                skt = createsketch(brepEdges)
                # can not get sketch's profile
                profilecurve = skt.profiles[0]
                # Create the patch feature by sketch's profile
                patches = _rootComp.features.patchFeatures
                patchInput = patches.createInput(profilecurve, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
                patches.add(patchInput)
        oresult[0] = 0
    except:
         _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# crate loop's sketch
def createsketch(brepEdges):
    try:
        oresult = -1
        skt :adsk.fusion.Sketch = _rootComp.sketches.add(_rootComp.xYConstructionPlane)
        skt.arePointsShown = False
        edge = brepEdges.item(0)
        edgegeo :adsk.core.NurbsCurve3D = None
        curveType = edge.geometry.curveType
        sktFits = None
        if curveType == 2:
            # Circle3DCurveType
            sktFits :adsk.fusion.SketchFixedSplines = skt.sketchCurves.sketchFixedSplines
        else:
            # NurbsCurve3DCurveType
            sktFits :adsk.fusion.SketchFittedSplines = skt.sketchCurves.sketchFittedSplines
        for edge in brepEdges:
            if curveType == 2:
                # Circle3DCurveType
                edgegeo = edge.geometry.asNurbsCurve
                sktFits.addByNurbsCurve(edgegeo)
            else:
                eva :adsk.core.SurfaceEvaluator = edgegeo.evaluator
                _, sPnt, ePnt = eva.getEndPoints()
                _, [sPrm, ePrm] = eva.getParametersAtPoints([sPnt, ePnt])
                # get Transit point
                _, pnts = eva.getStrokes(sPrm, ePrm, 0.01)
                pntLst = adsk.core.ObjectCollection.create()
                [pntLst.add(p) for p in pnts]
                sktFits.add(pntLst)
        skt.name = 'test'
        return skt
    except:
def stop(context):
    try:
        # Remove all of the event handlers your app has created
        futil.clear_handlers()
        commands.stop()
    except:
        futil.handle_error('stop')
tykapl.breuil
The problem you encounter is that a SketchProfile is, in my understanding, planar. You logically encounter a problem when trying to make a profile from a non planar edge. However, according to the documentation, a PatchFeature can take BRepGeometry, thus we should be able to forego using a sketch all together. I've tried to throw in a sample code, tell me if it works out for you.
# create patch
                oresult):
    try:
        oresult[0] = -1
        i = 0
        j = 0
                Loop: adsk.fusion.BRepLoop
                if Loop.isOuter:
                    # if Loop is Outer
                    continue
                pathEdgeCollection = adsk.core.ObjectCollection.create()
                [pathEdgeCollection.add(edge) for edge in brepEdges]
                path = adsk.fusion.Path.create(pathEdgeCollection, 0)
                global _rootComp
                    path,
        oresult[0] = 0
    except:
For the first sample, which gave you trouble, the script produced this :
MichaelT_123
Hi Mr. Ho-Kou,
Consider ... instead of creating sketch with profile to be used as a patch, split a face of target body with the surface body tool, and use the resulting cut-off face as a patch(s). Contrary to sketch profiles they don't need to be flat.
Look at the attached file. I believe that converting this idea to respective script would be ... a piece of cake 👩‍🍳 .
Regards
MichaelT
MichaelT
ho-kou
hi,Paul Breuil
Use your code,  i am succeed to create the patch,
thank you very much.
ho-kou
hi Michael Tomsia
thanks for your solution.
I try to do it.
