How can check brepedge’s direction?
ho-kou
ho-kou
I want to check whether the direction of the brepedge is clockwise or counterclockwise. Does anyone know how to do this?
Thank you for your help.
Jorge_Jaramillo
It is not clear for me your question at all.
When you think about direction it is from start point to the end of the curve?
Can you explain maybe with an image example?
kandennti
ho-kou
hi,
Thank you for your solution.
I want to check the direction by script(not by visualize), and use the direction to do next step.
Could you give me a solution which not by visualize.
ho-kou
hi, @kandennti san
Jorge_Jaramillo
I developed a function for that, and it worked in my tests:
import adsk, adsk.core, adsk.fusion, adsk.cam, traceback
import math
app = adsk.core.Application.get()
doc = app.activeDocument
des: adsk.fusion.Design = adsk.fusion.Design.cast(app.activeProduct)
root = des.rootComponent
def is_edge_clockwise(
        edge: adsk.fusion.BRepEdge,
        body_center: adsk.core.Point3D,
        face_centroid: adsk.core.Point3D,
    ) -> bool:
    normal_vector = body_center.vectorTo(face_centroid)
    normal_vector.normalize()
    vector1: adsk.core.Vector3D = body_center.vectorTo(edge.startVertex.geometry)
    vector2: adsk.core.Vector3D = body_center.vectorTo(edge.endVertex.geometry)
    cp = vector1.crossProduct(vector2)
    cp.normalize()
    return(abs(cp.angleTo(normal_vector)) > 0.5 * math.pi)
def check_direction_of_face_edges(face: adsk.fusion.BRepFace, body_center: adsk.core.Point3D) -> None:
    for n, edge in enumerate(face.edges):
        app.log(f'{n=} is_clockwise={is_edge_clockwise(edge, body_center, face.centroid)}')
        # Uncomment next line to add marks next to the start of every edge to check direction visually
        #add_mark_at_beginning_of_edge(edge, f'{n}')
def run(context) -> None:
    try:
        face = root.bRepBodies[0].faces[7]
        check_direction_of_face_edges(face, root.bRepBodies[0].getPhysicalProperties().centerOfMass)
    except:
        app.log('Failed:\n{}'.format(traceback.format_exc()))
    adsk.terminate()
def add_mark_at_beginning_of_edge(edge: adsk.fusion.BRepEdge, text: str) -> None:
    try:
        evaltr = edge.evaluator
        _, stParam, enParam = evaltr.getParameterExtents()
        _, mark_point = evaltr.getPointAtParameter(stParam + (enParam-stParam)*.15)
        if root.customGraphicsGroups.count:
            cus_graphics = root.customGraphicsGroups[0]
        else:
            cus_graphics = root.customGraphicsGroups.add()
        font_name = 'Arial'
        text_size = 2.0
        billboard_effect = adsk.fusion.CustomGraphicsBillBoard.create(None)
        show_through_color = adsk.fusion.CustomGraphicsShowThroughColorEffect.create(
            adsk.core.Color.create(0, 0, 250, 255), 1.0)
        transform = adsk.core.Matrix3D.create()
        transform.translation = adsk.core.Vector3D.create(mark_point.x, mark_point.y, mark_point.z)
        text_graphics: adsk.fusion.CustomGraphicsText = cus_graphics.addText(text, font_name, text_size, transform)
        text_graphics.billBoarding = billboard_effect
        text_graphics.color = show_through_color
    except:
        app.log(f'Failed:\n{traceback.format_exc()}')
The function is is_edge_clockwise() and have three parameters:
edge : the edge to analyze
body_center: body center point
face_centroid: face centroid where the edge belongs to
You can uncomment the line #29 in order to get some marks (edge index #) next to the start of each edge, just to visually check the results.
This is one of the tests I made:
I highlighted in red the edge that is clockwise and with red the counter-clockwise.
TO TEST: you just need some a design with some body on it, and in line #33 choose the body and face you want to analyze the edges to.
I hope this can help you.  Let me know if it works for you.
Jorge Jaramillo
ho-kou
hi Jorge_Jaramillo
your solution is works for me.
Thank you very much .
Regards,ho-kou
