How add a button in the Fusion 360 "navigation toolbar"
jean-jacques_juille
Message 1 of 14
jean-jacques_juille
I want to add a button in the Fusion 360 "navigation toolbar" that could simulate pressing the "Escape" key.
I thank you in advance.
Replies (13)
Message 2 of 14
j4n.vokurka
you can add a button to the NavBar like so:
 //declare constants
 std::string NavBarBtnID = "NavBarBtn";
 std::string NavBarBtnName = "NavBarBtn";
 //add commmand def
 Ptr<CommandDefinition> NavBarBtnCmdDef;
 NavBarBtnCmdDef = ui->commandDefinitions()->itemById(NavBarBtnID);
 if (!NavBarBtnCmdDef)
     NavBarBtnCmdDef = ui->commandDefinitions()->addButtonDefinition(NavBarBtnID, NavBarBtnName, "Sample btn", "");
 // add btn to the toolbar
 Ptr<Toolbar> navToolbar = ui->toolbars()->itemById("NavToolBar");
 Ptr<ToolbarControls> navToolbarControls = navToolbar->controls();
 bool wasAdded = navToolbarControls->addCommand(NavBarBtnCmdDef, "", false);
Message 3 of 14
jean-jacques_juille
I'm really sorry but I forgot to specify that I want this add-in in Python
Message 4 of 14
j4n.vokurka
For the most part (there are some language specific differences), it's just about transcribing the syntax since you still work with the same API. For that you can use AI if you are lazy like me, but here you go:
# Declare constants
navBarBtnID = "NavBarBtn"
navBarBtnName = "NavBarBtn"
# Add command definition
navBarBtnCmdDef = ui.commandDefinitions.itemById(navBarBtnID)
if not navBarBtnCmdDef:
    navBarBtnCmdDef = ui.commandDefinitions.addButtonDefinition(navBarBtnID, navBarBtnName, "Sample btn", "")
# Add button to the toolbar
navToolbar = ui.toolbars.itemById("navToolBar")
navToolbarControls = navToolbar.controls
wasAdded = navToolbarControls.addCommand(navBarBtnCmdDef, "", False)
Message 5 of 14
jean-jacques_juille
I created a new add-in in Python that I named "EscapeBtn", I edited the "EscapeBtn.py" file, I pasted your Python code just below the try def run(context) but apparently nothing is happening, I don't see a button added to my navigation toolbar (bottom). Forgive me but I'm a beginner and wonder if I pasted the code in the right place. Can you continue to help me?
Thanks in advance.
Message 6 of 14
j4n.vokurka
paste in the code please so I can check it.
Message 7 of 14
jean-jacques_juille
Below is the code for my Escapebtn.py file, Thank you for your patient :
# Assuming you have not changed the general structure of the template no modification is needed in this file.
from . import commands
from .lib import fusion360utils as futil
def run(context😞
    try:
        # Declare constants
        # This will run the start function in each of your commands as defined in commands/__init__.py
        commands.start()
    except:
        futil.handle_error('run')
def stop(context😞
    try:
        # Remove all of the event handlers your app has created
        futil.clear_handlers()
        commands.stop()
    except:
        futil.handle_error('stop')
Message 8 of 14
j4n.vokurka
I have written the whole add-in from start, here's the code:
import traceback
import adsk.fusion
import adsk.core
# Declare constants
_app: adsk.core.Application = None
_ui: adsk.core.UserInterface = None
_handlers = []
_navBarBtnID = "NavBarBtn"
_navBarBtnName = "NavBarBtn"
_toolbar = "NavToolbar"
def run(context):
    try:
        global _app, _ui, _handlers, _navBarBtnID, _navBarBtnName, _toolbar
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        navBarBtnCmdDef = _ui.commandDefinitions.itemById(_navBarBtnID)
            navBarBtnCmdDef = _ui.commandDefinitions.addButtonDefinition(_navBarBtnID, _navBarBtnName, "Sample btn", "Resources")
        # Connect to the command created event.
        sampleCommandCreated = SampleCommandCreatedEventHandler()
        navBarBtnCmdDef.commandCreated.add(sampleCommandCreated)
        _handlers.append(sampleCommandCreated)
        # for toolbar in _ui.toolbars:
        #     _app.log(toolbar.id)
        navToolbar = _ui.toolbars.itemById(_toolbar)
        escapeBtn = navToolbarControls.addCommand(navBarBtnCmdDef, "", False)
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# Event handler for the commandCreated event.
class SampleCommandCreatedEventHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        eventArgs = adsk.core.CommandCreatedEventArgs.cast(args)
        cmd = eventArgs.command
        global _app, _handlers
        _ui.messageBox("Implement your logic here.")
def stop(context):
    try:
        # Clean up the UI.
        cntrl = navToolbarControls.itemById(_navBarBtnID)
        if cntrl:
            cntrl.deleteMe()
            navBarBtnCmdDef.deleteMe()
    except:
        if _ui:
Don't forget to adjust the path to icon to your own on line 22.
Message 9 of 14
jean-jacques_juille
Hi
I just tried your code and it works great. I just had a problem with the icon path. I had to replace the relative path of the icons with the absolute path. I am really pleased with your help and thank you very much.
Message 10 of 14
juha2008
I spent quite a lot of time trying to get buttons and icons working—probably several hours in total.
I wanted to promote a custom button to the toolbar from my Add-In, but it wouldn't work without an icon. Finding the correct paths to the icon felt like higher science!
Here's the code that finally worked for me:
cmd_definitions = ui.commandDefinitions
button = cmd_definitions.itemById('updateTextCommand')
if not button:
        button = cmd_definitions.addButtonDefinition('updateTextCommand', 'ButtonText', 'ButtonDescription', './Resources/Command')
Initially, I tried putting the images in the same folder as my Python code within the Add-In folder, but that didn't work. Eventually, I created a subfolder called Resources and another subfolder inside that named Command. I placed the images there for testing, and the file names that worked were: 32x32-normal.svg or 32x32-normal.png.
Important note: Fusion 360 seems to load all resources when it starts up. I wasted a lot of time before realizing that I needed to restart Fusion for the changes to take effect. Once I did that, everything worked fine. I tried so many different things that it's possible other setups would have worked after a restart—but I don't have the energy to test them all again!
I'm still unsure if the file naming is exactly right, but it seems to work. If you're looking for more info, you might want to check this reference: Fusion 360 Icon Reference.
Just wanted to share my experience for anyone else struggling with the same issue. Hope this helps!
Message 11 of 14
nubrandao
i just created a button, but now how can i add a script to run when pushing the new botton?
Message 12 of 14
juha2008
Here is my full Add-In code for reference. Please note to create Add-In instead of Script.
I have a model with user parameter which I could increase and decrease by 5 mm. Then if I change HeightQ paramter manually, then I have button to refresh certain sketch with text to have the dimension in it. For example parameter value is 15 mm, then sketch will have text in it "15 mm".
import os
import adsk.core, adsk.fusion
ui = app.userInterface
handlers = []
# Funktiot, joilla kasvatetaan ja pienennetään parametriarvoa ja päivitetään teksti
def change_height_param(increment):
    try:
        design = app.activeProduct
        if not design:
            ui.messageBox('Ei aktiivista suunnittelua')
            return
        userParams = design.userParameters
        heightParam = userParams.itemByName('HeightQ')
        if heightParam:
            new_value = heightParam.value + (increment / 10)  # Muutos senttimetreissä
            heightParam.value = new_value
            update_text_with_height_param()  # Päivitetään luonnoksen teksti
        else:
            ui.messageBox('Parametri HeightQ ei löytynyt')
    except Exception as e:
        ui.messageBox(f'Virhe parametrin muuttamisessa: {str(e)}')
# Tekstin päivitystoiminto (sama kuin ennen)
def update_text_with_height_param():
    try:
        if not design:
            return
        rootComp = design.rootComponent
        if not rootComp:
            ui.messageBox('Ei komponenttia saatavilla')
            return
        sketches = rootComp.sketches
        for sketch in sketches:
            if sketch.name == 'HeightText':
                if heightParam:
                    heightValue = int(heightParam.value * 10)  # Muunna senttimetreistä millimetreiksi
                    sketchTexts = sketch.sketchTexts
                    if sketchTexts.count > 0:
                        textElement = sketchTexts.item(0)
                        textElement.text = str(heightValue) + ' mm'
                    else:
                        ui.messageBox('Ei tekstielementtejä luonnoksessa')
                else:
        ui.messageBox(f'Virhe tekstin päivityksessä: {str(e)}')
# Käsittelijät eri komennoille ilman ID-viittauksia
class IncreaseCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            command = eventArgs.command
            onExecute = IncreaseCommandExecuteHandler()
            command.execute.add(onExecute)
            handlers.append(onExecute)
            ui.messageBox(f'Virhe Increase-komennon luonnissa: {str(e)}')
class IncreaseCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            change_height_param(5)  # Kasvatetaan 5 mm
            ui.messageBox(f'Virhe Increase-komennossa: {str(e)}')
class DecreaseCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            onExecute = DecreaseCommandExecuteHandler()
            ui.messageBox(f'Virhe Decrease-komennon luonnissa: {str(e)}')
class DecreaseCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            change_height_param(-5)  # Pienennetään 5 mm
            ui.messageBox(f'Virhe Decrease-komennossa: {str(e)}')
class RefreshCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            onExecute = RefreshCommandExecuteHandler()
            ui.messageBox(f'Virhe Refresh-komennon luonnissa: {str(e)}')
class RefreshCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            update_text_with_height_param()  # Päivitä tekstielementti luonnoksessa
            ui.messageBox(f'Virhe Refresh-komennossa: {str(e)}')
# Komennon luonti
def create_adjustment_buttons():
    try:
        # Selvitä Add-Inin hakemisto ja muodosta oikea polku kuvakkeille
        addin_path = os.path.dirname(os.path.realpath(__file__))
        resources_path = os.path.join(addin_path, 'Resources')
        # Lisää Increase-nappula
        increase_button = ui.commandDefinitions.itemById('increaseHeightCommand')
        if not increase_button:
            increase_button = ui.commandDefinitions.addButtonDefinition(
                'increaseHeightCommand', 'Increase Height', 'Kasvattaa Height-parametrin arvoa 5 mm',
                os.path.join(resources_path, 'Plus')
        # Lisää Decrease-nappula
        decrease_button = ui.commandDefinitions.itemById('decreaseHeightCommand')
        if not decrease_button:
            decrease_button = ui.commandDefinitions.addButtonDefinition(
                'decreaseHeightCommand', 'Decrease Height', 'Pienentää Height-parametrin arvoa 5 mm',
                os.path.join(resources_path, 'Minus')
        # Lisää Refresh-nappula
        refresh_button = ui.commandDefinitions.itemById('refreshHeightCommand')
        if not refresh_button:
            refresh_button = ui.commandDefinitions.addButtonDefinition(
                'refreshHeightCommand', 'Refresh', 'Päivitä tekstielementti parametrin perusteella',
                os.path.join(resources_path, 'Refresh')
        # Rekisteröi Increase-komento
        onIncreaseCreated = IncreaseCommandCreatedHandler()
        increase_button.commandCreated.add(onIncreaseCreated)
        handlers.append(onIncreaseCreated)
        # Rekisteröi Decrease-komento
        onDecreaseCreated = DecreaseCommandCreatedHandler()
        decrease_button.commandCreated.add(onDecreaseCreated)
        handlers.append(onDecreaseCreated)
        # Rekisteröi Refresh-komento
        onRefreshCreated = RefreshCommandCreatedHandler()
        refresh_button.commandCreated.add(onRefreshCreated)
        handlers.append(onRefreshCreated)
        # Lisää nappulat Modify-paneeliin ja promoted-tilaan
        workspace = ui.workspaces.itemById('FusionSolidEnvironment')
        toolbar_tab = workspace.toolbarTabs.itemById('SolidTab')
        modify_panel = toolbar_tab.toolbarPanels.itemById('SolidModifyPanel')
        if modify_panel:
            increase_control = modify_panel.controls.itemById('increaseHeightCommand')
            if not increase_control:
                increase_control = modify_panel.controls.addCommand(increase_button)
            increase_control.isPromoted = True
            decrease_control = modify_panel.controls.itemById('decreaseHeightCommand')
            if not decrease_control:
                decrease_control = modify_panel.controls.addCommand(decrease_button)
            decrease_control.isPromoted = True
            refresh_control = modify_panel.controls.itemById('refreshHeightCommand')
            if not refresh_control:
                refresh_control = modify_panel.controls.addCommand(refresh_button)
            refresh_control.isPromoted = True
        ui.messageBox(f'Virhe komennon luomisessa: {str(e)}')
# Komennon käynnistys
def run(context):
    try:
        create_adjustment_buttons()  # Luo Increase, Decrease ja Refresh -nappulat käyttöliittymään
        ui.messageBox(f'Virhe run-funktiossa: {str(e)}')
# Komennon lopetus
def stop(context):
    try:
        # Poista kaikki komennot ja tapahtumakäsittelijät
        # Poista Increase-nappula
        increase_button = cmd_definitions.itemById('increaseHeightCommand')
        if increase_button:
            increase_button.deleteMe()
        # Poista Decrease-nappula
        decrease_button = cmd_definitions.itemById('decreaseHeightCommand')
        if decrease_button:
            decrease_button.deleteMe()
        # Poista Refresh-nappula
        refresh_button = cmd_definitions.itemById('refreshHeightCommand')
        if refresh_button:
            refresh_button.deleteMe()
        if modify_panel:
            if increase_control:
                increase_control.deleteMe()
            if decrease_control:
                decrease_control.deleteMe()
            if refresh_control:
                refresh_control.deleteMe()
        global handlers
        handlers = []
        ui.messageBox(f'Virhe stop-funktiossa: {str(e)}')
I made this partly by help of ChatGPT.
Screenshot what kind of parameter model I have to update height and text on top surface of it.
To get it all english, here is same code translated by ChatGPT (I cannot validate whether this is working or not, upper one is working for sure).
import os
handlers = []
# Functions to increase and decrease the parameter value and update the text
    try:
        if not design:
            ui.messageBox('No active design')
            return
        if heightParam:
            new_value = heightParam.value + (increment / 10)  # Change in centimeters
            update_text_with_height_param()  # Update the sketch text
        else:
            ui.messageBox('Parameter HeightQ not found')
        ui.messageBox(f'Error changing parameter: {str(e)}')
# Text update function (same as before)
    try:
        if not design:
            return
        if not rootComp:
            ui.messageBox('No component available')
            return
                if heightParam:
                    heightValue = int(heightParam.value * 10)  # Convert from centimeters to millimeters
                    else:
                        ui.messageBox('No text elements in the sketch')
                else:
        ui.messageBox(f'Error updating text: {str(e)}')
# Handlers for different commands without ID references
    def __init__(self):
        super().__init__()
        try:
            ui.messageBox(f'Error creating Increase command: {str(e)}')
    def __init__(self):
        super().__init__()
        try:
            change_height_param(5)  # Increase by 5 mm
            ui.messageBox(f'Error executing Increase command: {str(e)}')
    def __init__(self):
        super().__init__()
        try:
            ui.messageBox(f'Error creating Decrease command: {str(e)}')
    def __init__(self):
        super().__init__()
        try:
            change_height_param(-5)  # Decrease by 5 mm
            ui.messageBox(f'Error executing Decrease command: {str(e)}')
    def __init__(self):
        super().__init__()
        try:
            ui.messageBox(f'Error creating Refresh command: {str(e)}')
    def __init__(self):
        super().__init__()
        try:
            update_text_with_height_param()  # Update the text element in the sketch
            ui.messageBox(f'Error executing Refresh command: {str(e)}')
# Command creation
    try:
        # Determine Add-In directory and form the correct path for icons
        # Add Increase button
                'increaseHeightCommand', 'Increase Height', 'Increase Height parameter by 5 mm',
        # Add Decrease button
                'decreaseHeightCommand', 'Decrease Height', 'Decrease Height parameter by 5 mm',
        # Add Refresh button
                'refreshHeightCommand', 'Refresh', 'Update text element based on parameter',
        # Register Increase command
        # Register Decrease command
        # Register Refresh command
        # Add buttons to the Modify panel and promote them
        if modify_panel:
        ui.messageBox(f'Error creating command: {str(e)}')
# Command start
def run(context):
    try:
        create_adjustment_buttons()  # Create Increase, Decrease, and Refresh buttons in the UI
        ui.messageBox(f'Error in run function: {str(e)}')
# Command stop
def stop(context):
    try:
        # Remove all commands and event handlers
        # Remove Increase button
        if increase_button:
        # Remove Decrease button
        if decrease_button:
        # Remove Refresh button
        if refresh_button:
        if modify_panel:
            if refresh_control:
        global handlers
        handlers = []
        ui.messageBox(f'Error in stop function: {str(e)}')
Message 13 of 14
juha2008
Buttons on the Toolbar:
Resources folder structure and files (Command folder were just testing):
Also 16x16-normal.png files is also extra and they are not... Well.. After quick double check. They are used in dropdown toolbar apparently. So those I need to update for better look:
Message 14 of 14
nubrandao
for example, i used chatgpt to create a button,
import adsk.core, adsk.fusion, traceback
def run(context😞
    try:
        # Activate the CAM (Manufacture) workspace
        workspaces = ui.workspaces
        manufacture_workspace = workspaces.itemById('CAMEnvironment')
        manufacture_workspace.activate()
        # Create a command definition for the button
        cmd_def = ui.commandDefinitions.addButtonDefinition('MyCAMToolButton',
                                                            'Run CAM Tool',
                                                            'This button runs my custom CAM tool.')
        # Define the custom action that will run when the button is clicked
        on_command_created = MyCommandCreatedHandler()
        cmd_def.commandCreated.add(on_command_created)
        handlers.append(on_command_created)
        # Add the button to the CAMJobPanel
        cam_job_panel = ui.allToolbarPanels.itemById('CAMJobPanel')
        if cam_job_panel:
            cam_job_panel.controls.addCommand(cmd_def)
            ui.messageBox('Button added to CAMJobPanel!')
    except:
        if ui:
def stop(context😞
    try:
        # Clean up the UI elements when the add-in is stopped
        cmd_def = ui.commandDefinitions.itemById('MyCAMToolButton')
        if cmd_def:
            cmd_def.deleteMe()
        # Remove the button from the CAMJobPanel
        if cam_job_panel:
            cntrl = cam_job_panel.controls.itemById('MyCAMToolButton')
            if cntrl:
                cntrl.deleteMe()
    except:
        if ui:
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler😞
    def __init__(self😞
        super().__init__()
    def notify(self, args😞
        try:
            # Run your custom script or function here
            ui.messageBox('Custom CAM script is running!')
            # You can include your actual CAM tool script or logic here
            # For example, accessing toolpath data, generating G-code, etc.
        except:
            if ui:
                ui.messageBox('Command execution failed:\n{}'.format(traceback.format_exc()))
# Event handlers array to prevent garbage collection
handlers = []
but everytime i try to add the script, dont work, how can i add a script inside the button?
