highlighting a features
Hi  every body .. this forum is really help to me ... i have been learning a lot from this forum. thankyou soo much for all you help...!
          i need help in highlighting a feature in an occurrence....
here is the code i am using...  design file is attached below... keep the code and design file in the same directory... i want to highlight a feature named 'hole'  ...
import adsk.core, adsk.fusion, traceback
import os.path, sys
numberOfTeeths = 25
internalDia = 10
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
# Get import manager
importManager = app.importManager
# Get active design
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
# Get root component
rootComp = design.rootComponent
# Get archive import options and importing files
archiveFileName = os.path.join(os.path.dirname(os.path.realpath(__file__)), '1.f3d')
archiveOptions = importManager.createFusionArchiveImportOptions(archiveFileName)
#getting occurence
importManager.importToTarget(archiveOptions, rootComp)
pulleyOccurrence = rootComp.occurrences.item(rootComp.occurrences.count-1)
parametersList = pulleyOccurrence.component.parentDesign.allParameters
numberOfTeethspara = parametersList.itemByName('nt')
InternalDiapara = parametersList.itemByName('id')
numberOfTeethspara.expression = str(numberOfTeeths)
InternalDiapara.expression = str(internalDia)
pulleyComponent = pulleyOccurrence.component
holeFeature = pulleyComponent.features.extrudeFeatures.itemByName('hole')
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
marshaltu
Please give a try and see if the following codes work for you. We had to wait for some time(e.g. 1s) before selecting "hole" feature because there was a timing issue. Otherwise the "hole" feature could not be highlighted in scene, only selected in timeline. You can extend the time longer if 1s doesn't work for you.
Marshal
import os.path, sys, time
numberOfTeeths = 25
internalDia = 10
def run(context):
    ui = None
    try:
        # Get active design
        #getting occurence
        for i in range(100):
            time.sleep(0.01)
            adsk.doEvents()
        holeFeatProxy = holeFeature.createForAssemblyContext(pulleyOccurrence)
        ui.activeSelections.add(holeFeatProxy)
    except:
        if ui:
Marshal Tu
Fusion Developer
thankyou soo much .... its works perfectly ... but can you plz explain this part of code marked red .. i understand that  time.sleep is needed to give processor some time.. but the rest i dont understand... i actually wanted to use that hole feature and and a cylinder to make a revolute joint.. but could not select that hole feature... thankyou soo much for your help and time..!
time.sleep(0.01)
adsk.doEvents()
marshaltu
"adsk.doEvents()" gives Fusion a chance to react during sleeping. We have some detailed description about the method in "Python Specific Issues" -> "Miscellaneous".
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-743C88FB-CA3F-44B0-B0B9-FCC378D0D782
A proxy object(extrude feature) with absolute path from root component is needed to create selection. Otherwise, "ui.activeSelections.add()" will fail. For proxy objects, please refer to the help "Document and Assembly Structure" for more details.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-88A4DB43-CFDD-4CFF-B124-7EE67915A07A
Marshal
Marshal Tu
Fusion Developer
marshaltu
I am aware there is no need to do sleep instead we can call adsk.doEvents() to let Fusion have a chance to refresh UI/finish compute. The codes look as below:
import os.path, sys
numberOfTeeths = 25
internalDia = 10
def run(context):
    ui = None
    try:
        # Get active design
        #getting occurence
        adsk.doEvents()
    except:
        if ui:
Marshal Tu
Fusion Developer
thank you soo much sir
