Help with API - description model
Marek_Skotak
Marek_Skotak
Hi All,
 im writing one python macro and i would need read this parameter from a model.
Can someone help me with this please?
Thanks very much.
Postprocessor writer, CNC trainer, .NET programmer, www.cadcam-softcz.cz
Accepted solutions (3)
PinRudolf
Note that you grab the occurrence when you're selecting something from a design. Make sure to find the component before getting the properties. The code should look something like this:
occurrence.component.description
Marek_Skotak
There is a part of code for a looking component description which i used. For everyone who will looking it 🙂
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        # get all components in this design
        allComps = design.allComponents
        for comp in allComps:
          ui.messageBox('comp description = ' + comp.description)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
