Help on API custom command to create a sweep through an unchained edge selection
2way3dtext
2way3dtext
May I receive some advice on adjusting this add-in to be able to select edges as an unchained option? The following code only allows for chained selection of edges.
            path_Input = inputs.addSelectionInput('path_Input', 'Path', 'Select path of pipe')
            path_Input.setSelectionLimits(1,1)
            path_Input.addSelectionFilter('Edges')
            path_Input.addSelectionFilter('SketchCurves')
I was able to use an unchained edge selection with a following code as a script, however the same code does not work as an add-in.
        sel = ui.selectEntity('Select a path to create a pipe', 'Edges,SketchCurves')
        selObj = sel.entity
        chainedOption = adsk.fusion.ChainedCurveOptions.noChainedCurves
        path = adsk.fusion.Path.create(selObj, chainedOption)
Is there a way to convert the script code to be suitable as an Add-in? Which websites would be recommended when researching specific API lines and sample API codes (including the fusion 360 website) in the future?
kandennti
Hi @2way3dtext .
There are probably two causes.
def CreateRoundedEndPipe(path, pipeDiameter) :
    try:
        pipeRadius = pipeDiameter/2
        product = _app.activeProduct
        design = adsk.fusion.Design.cast(product)
        comp = design.rootComponent
        selObj: adsk.fusion.BRepEdge = path
        # create path
        feats = comp.features
        # chainedOption = adsk.fusion.ChainedCurveOptions.connectedChainedCurves # <- It's here.
        if adsk.fusion.BRepEdge.cast(selObj):
            chainedOption = adsk.fusion.ChainedCurveOptions.tangentChainedCurves
        # path = feats.createPath(selObj) # <- It's here.
I've pointed out one of them here.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/help-for-api-script-to-create-a-pipe-with-...
2way3dtext
@kandennti
Thank you so much for your generous help.
When I fixed the code as you have shown me, I was able to select an unchained edge!
I am learning more about coding in API thanks to your continued support.
