Hello addin
Hello addin
Hello addin
since one of the latest update, I do have a strange "Hello addin" alert message at start and "Stop addin" when I close the software.
I also had an issue with slicer, I uninstall it but the issue is still there.
I also looked for others addin, stop, and disable them at start but nothing change.
How I could find the guilty one ?
Thank you
BrianEkins
I would start by looking at the Add-Ins tab of the Scripts and Add-Ins dialog and look to see which add-ins are running. Since you're seeing a message when Fusion starts and another when it stops, the add-in must be running.  The add-ins that are running will have the circle of dots to the right of the add-in name.  You can select an add-in from the list and click the "Stop" button.  That will unload it.  When you do this for the add-in that's popping the dialog, you should see the "Stop addin" message box.  Uncheck the "Run on Startup" for this add-in.  Since you didn't change the "Run on Startup" for the other add-ins, restarting Fusion should reset everything and you'll be back to your original state except the problem add-in will no longer load.
Brian Ekins
thank you for you answer. I already tried that but it didn't worked.
I think I will uninstall and reinstall
i also have the hello add-ins and stop add ins, very anoying, wish someone could find a cure
kandennti
Hi @Anonymous .
If you do "Clear cache data", will there be any change?
However, please be careful.
I don't know how much of an effect this will have, but it may cause various settings to revert to default.
I have managed to relolve this, uninstalling. removing manually every fusion folders except Fusion CAM, reinstall and then it was gone. i think even uninstalling, some API folders stay there and it was an issue.
Thank you Kandennti, it worked perfectly for me !
