[HANG] app.documents.open(dataFile=drawingFile, visible=False)
gvisca44
Message 1 of 1
gvisca44
Hi there,
I've been writing a script to export a bunch of drawing files to PDFs.
When visible is set to TRUE ...documents.open(dataFile=drawingFile, visible=True) all is OK.
But - when visible is set to False - Fusion hangs.
Seems like the drawing file opens (I can see the component browser) - the toolbar is a little whacky - no drawing per se - and Fusion just sits still.
import adsk.core
import adsk.fusion
import adsk.drawing
import traceback
app = None
ui = None
design:adsk.fusion.Design = None
def run(context):
    global app, ui, design
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        drawingFiles:adsk.core.DataFiles = getDrawingFiles()
        adsk.doEvents()
        #outputFolder:adsk.core.DataFolder = getDrawingOutputFolder()
        outputDirectory = getDrawingOutputDirectory()
        for drawingFile in drawingFiles:
            #doc:adsk.core.Document = app.documents.open(drawingFile)
            drawingDoc:adsk.drawing.DrawingDocument = app.documents.open(dataFile=drawingFile, visible=True)
            #drawingFile.
            exportDrawingToPdf(drawingDoc, outputDirectory)
            drawingDoc.close(saveChanges=False)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getDrawingFiles() -> adsk.core.DataFiles:
    cloudDialog = ui.createCloudFileDialog()
    cloudDialog.title = 'Select drawings to export.'
    cloudDialog.isMultiSelectEnabled = True
    cloudDialog.filter = 'f2d'
    dialogResult = cloudDialog.showOpen()
    if dialogResult == adsk.core.DialogResults.DialogOK:
        #dataFolder:adsk.core.DataFolder = cloudDialog.dataFolder
        dataFiles:adsk.core.DataFiles = cloudDialog.dataFiles
        return dataFiles
def getDrawingOutputFolder() -> adsk.core.DataFolder:
    cloudDialog.title = 'Select output folder.'
    dialogResult = cloudDialog.showSave()
        return dataFolder
def getDrawingOutputDirectory():
    folderDialog = ui.createFolderDialog()
    folderDialog.title = 'Selection output folder.'
    dialogResult = folderDialog.showDialog()
        foldername = folderDialog.folder
        return foldername
    else:
        return
def exportDrawingToPdf(
        drawingDoc:adsk.drawing.DrawingDocument,
        outputDir:str
    msg = f'{drawingDoc.name}'
    app.log(msg)
    #msg = f'{outputFolder.name}'
    #app.log(msg)
    msg = f'{outputDir}'
    app.log(msg)
    outputFileName = drawingDoc.name
    filename = outputDir + '/' + outputFileName + '.pdf'
    exportManager:adsk.drawing.DrawingExportManager = drawingDoc.drawing.exportManager
    PDFOptions:adsk.drawing.PDFExportOptions = exportManager.createPDFExportOptions(filename)
    PDFOptions.filename = filename
    PDFOptions.sheetsToExport = adsk.drawing.PDFSheetsExport.AllPDFSheetsExport
    PDFOptions.openPDF = False
    PDFOptions.useLineWeights = False
    exportOK = exportManager.execute(PDFOptions)
    return exportOK
Cheers !
Glenn.
Replies (0)
