Getting the path from the inported file.
pedro_babo
pedro_babo
I'm creating a script to Export the visible faces to the same path that I've imported the first file.
I’m using this code.
def get_imported_file_path():
    # Get the active design
    app = adsk.core.Application.get()
    design = adsk.fusion.Design.cast(app.activeProduct)
    # Get the root component
    root_comp = design.rootComponent
    # Get the first occurrence in the root component
    #first_occurrence = root_comp.occurrences.item(0)
    # Get the import component of the first occurrence
    #import_comp = adsk.fusion.ImportComponent.cast(first_occurrence.component)
    # Get the full path of the imported file
    #import_path = import_comp.importedFileName
    # Notify the user of the imported file path
    return root_comp.name
Has I've not saved any model I get "not saved".
The objective is exporting a SAT file back to the same location on the PC of the original file.
Is there any other Way?
kandennti
Hi @pedro_babo .
There is no object called "adsk.fusion.ImportComponent."
What kind of comport are you referring to when you say "import component"?
Do you mean a component with external links?
It would be easier to understand if you could attach the f3d/f3z files.
pedro_babo
Hi Kandennti
First thanks for replying.
I’ve also looked for it and didn’t find it.
I’m importing a local SAT file into Fusion. Make some surfaces and need a way to get the path from the imported geometry file to export back one other file.
How can I Get that Path.
kandennti
@pedro_babo .
Basically, there should be no function in the occurrence or component to record the imported path.
Therefore, it is necessary to create some kind of mechanism to record the path when performing the import process.
As an example, the file path is recorded in the attributes of the occurrence that is created when the file is imported.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-33519517-DC34-4B04-91A7-27E40AD2D010
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
SAT_IMPORT_ATTR: dict = {
    'group': 'sat_import_test',
    'name': 'path'
def run(context):
    ui = core.UserInterface.cast(None)
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        # get sat filepath
        path = get_filepath()
        if len(path) < 1:
            return
        # import sat file & add path to attribute
        occ: fusion.Occurrence = import_sat(
            path,
            SAT_IMPORT_ATTR,
        # attribute path checking
        attr: core.Attribute = occ.attributes.itemByName(
            SAT_IMPORT_ATTR['group'],
            SAT_IMPORT_ATTR['name'],
        if not attr:
            return
        ui.messageBox(attr.value)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def import_sat(path: str, attrInfo: dict) -> fusion.Occurrence:
    impMgr: core.ImportManager = app.importManager
    satOpt: core.SATImportOptions = impMgr.createSATImportOptions(path)
    des: fusion.Design = app.activeProduct
    root: fusion.Component = des.rootComponent
    occLst: core.ObjectCollection = impMgr.importToTarget2(satOpt, root)
    occSat: fusion.Occurrence = occLst.item(0)
    occSat.attributes.add(
        attrInfo['group'],
        attrInfo['name'],
        path,
    return occSat
def get_filepath() -> str:
    ui: core.UserInterface = core.Application.get().userInterface
    dlg = ui.createFileDialog()
    dlg.title = 'SAT Import'
    dlg.isMultiSelectEnabled = False
    dlg.filter = 'SAT(*.sat)'
    if dlg.showOpen() != core.DialogResults.DialogOK :
        return ''
    return dlg.filename
In the last part, the import path is called from an attribute of the actual imported occurrence.
pedro_babo
Hi @Kindenty.
I was already thinking about some way to do this. I was thinking about description of root component.
Thanks this is one invisible way for the user.
Is there a way to run this scripts upon double clicking a SAT file that will start FusionLauncher?
kandennti
@pedro_babo .
You can't do that with scripts.
I think it would be possible to change it to an add-in and use the UserInterface.commandTerminated event.
pedro_babo
Thanks @kandennti this need to be mature But I will post the Ideas.
