Geting this API working.
pedro_babo
pedro_babo
Hi I've developde a scrip based on @BrianEkins CenterOfRange.
It creates points on each middle face of the bounding box.
I'm trying to transform it into one add-In but I always get fusion to crash.
Could some one look at this and figure out what is wrong?
the code:
    # TODO ******************************** Your code here ********************************
    # Get all components in the active design.
    doc = app.activeDocument
    des = doc.products[0]
    _ui = app.userInterface
    if not des:
        _ui.messageBox('No active Fusion design', 'Center of Bounds')
        return
    # Have a body selected.
    bodySelection = _ui.selectEntity('Select the body', 'MeshBodies,Bodies')
    if not bodySelection:
        return False
    drawBox = False
    if _ui.messageBox('Draw the bounding box points?', 'Bounding Box Center Points', adsk.core.MessageBoxButtonTypes.YesNoButtonType, adsk.core.MessageBoxIconTypes.QuestionIconType) == adsk.core.DialogResults.DialogYes:
        drawBox = True
    # Check to see if a b-rep or mesh body was selected.
    triMesh = adsk.fusion.TriangleMesh.cast(None)
    if isinstance(bodySelection.entity, adsk.fusion.BRepBody):
        brepBody = adsk.fusion.BRepBody.cast(bodySelection.entity)
        triMesh = brepBody.meshManager.displayMeshes.bestMesh
        body = brepBody
    elif isinstance(bodySelection.entity, adsk.fusion.MeshBody):
        meshBody = adsk.fusion.MeshBody.cast(bodySelection.entity)
        triMesh = meshBody.displayMesh
        body = meshBody
    # Calculate the bounding box of the mesh.
    smallPnt = adsk.core.Point3D.cast(triMesh.nodeCoordinates[0])
    largePnt = adsk.core.Point3D.cast(triMesh.nodeCoordinates[0])
    vertex = adsk.core.Point3D.cast(None)
    for vertex in triMesh.nodeCoordinates:
        if vertex.x < smallPnt.x:
            smallPnt.x = vertex.x
        if vertex.y < smallPnt.y:
            smallPnt.y = vertex.y
        if vertex.z < smallPnt.z:
            smallPnt.z = vertex.z
        if vertex.x > largePnt.x:
            largePnt.x = vertex.x
        if vertex.y > largePnt.y:
            largePnt.y = vertex.y
        if vertex.z > largePnt.z:
            largePnt.z = vertex.z
    #center Points.
    centerPnt = adsk.core.Point3D.create((smallPnt.x+largePnt.x)/2, (smallPnt.y+largePnt.y)/2, (smallPnt.z+largePnt.z)/2)
    centerXMinusPnt = adsk.core.Point3D.create(smallPnt.x, (smallPnt.y+largePnt.y)/2, (smallPnt.z+largePnt.z)/2)
    centerXPlusPnt = adsk.core.Point3D.create(largePnt.x, (smallPnt.y+largePnt.y)/2, (smallPnt.z+largePnt.z)/2)
    centerYMinusPnt = adsk.core.Point3D.create((smallPnt.x+largePnt.x)/2, smallPnt.y, (smallPnt.z+largePnt.z)/2)
    centerYplusPnt = adsk.core.Point3D.create((smallPnt.x+largePnt.x)/2, largePnt.y, (smallPnt.z+largePnt.z)/2)
    #center Corner Points.
    centerCornerXPlusYPlusPnt = adsk.core.Point3D.create(largePnt.x, largePnt.y, (smallPnt.z+largePnt.z)/2)
    centerCornerXPlusYMinusPnt = adsk.core.Point3D.create(largePnt.x, smallPnt.y, (smallPnt.z+largePnt.z)/2)
    centerCornerXMinusYPlusPnt = adsk.core.Point3D.create(smallPnt.x, largePnt.y, (smallPnt.z+largePnt.z)/2)
    centerCornerXMinusYminusPnt = adsk.core.Point3D.create(smallPnt.x, smallPnt.y, (smallPnt.z+largePnt.z)/2)
    #center Top Points.
    centerTopPnt = adsk.core.Point3D.create((smallPnt.x+largePnt.x)/2, (smallPnt.y+largePnt.y)/2,largePnt.z)
    centerTopXMinusPnt = adsk.core.Point3D.create(smallPnt.x, (smallPnt.y+largePnt.y)/2, largePnt.z)
    centerTopXPlusPnt = adsk.core.Point3D.create(largePnt.x, (smallPnt.y+largePnt.y)/2, largePnt.z)
    centerTopYMinusPnt = adsk.core.Point3D.create((smallPnt.x+largePnt.x)/2, smallPnt.y, largePnt.z)
    centerTopYplusPnt = adsk.core.Point3D.create((smallPnt.x+largePnt.x)/2, largePnt.y, largePnt.z)
    #center Bottom Points.
    centerBotomPnt = adsk.core.Point3D.create((smallPnt.x+largePnt.x)/2, (smallPnt.y+largePnt.y)/2, smallPnt.z)
    centerBotomXMinusPnt = adsk.core.Point3D.create(smallPnt.x, (smallPnt.y+largePnt.y)/2, smallPnt.z)
    centerBotomXPlusPnt = adsk.core.Point3D.create(largePnt.x, (smallPnt.y+largePnt.y)/2, smallPnt.z)
    centerBotomYMinusPnt = adsk.core.Point3D.create((smallPnt.x+largePnt.x)/2, smallPnt.y, smallPnt.z)
    centerBotomYplusPnt = adsk.core.Point3D.create((smallPnt.x+largePnt.x)/2, largePnt.y, smallPnt.z)
    # Get the root component of the active design
    rootComp = des.rootComponent
    # Special case for parametric or direct edit design.
    if des.designType == adsk.fusion.DesignTypes.ParametricDesignType:
        # Check to see if a base feature named "Center of Bounds" exists.
        baseFeature = rootComp.features.itemByName('Center of Block')
        if not baseFeature:
            # Create a new base feature.
            baseFeature = rootComp.features.baseFeatures.add()
            baseFeature.name = 'Center of Block'
        # Begin editing the base feature.
        baseFeature.startEdit()
        inEdit = True
        # Get the full path of the body.
        bodyName = getPath(body) + '/' + body.name
        # Check to see if there's already a sketch for this body.
        skAttribs = des.findAttributes('CenterOfBounds', bodyName)
        if len(skAttribs) > 0:
            skAttrib = skAttribs[0]
            if skAttrib.parent:
                sketch = adsk.fusion.Sketch.cast(skAttrib.parent)
                # Delete the contents of the sketch.
                ents = adsk.core.ObjectCollection.create()
                for line in sketch.sketchCurves.sketchLines:
                    ents.add(line)
                for pnt in sketch.sketchPoints:
                    ents.add(pnt)
                des.deleteEntities(ents)
            else:
                skAttrib.deleteMe()
                sketch = rootComp.sketches.add(rootComp.xYConstructionPlane)
                sketch.baseOrFormFeature = baseFeature
                sketch.attributes.add('CenterOfBounds', bodyName, '')
        else:
            sketch.name = 'Centre of Block'
        sketch.areProfilesShown = False
        sketch.areDimensionsShown = True
        #center Points.
        sketch.sketchPoints.add(centerPnt)
        sketch.sketchPoints.add(centerXMinusPnt)
        sketch.sketchPoints.add(centerXPlusPnt)
        sketch.sketchPoints.add(centerYMinusPnt)
        sketch.sketchPoints.add(centerYplusPnt)
        sketch.sketchPoints.add(centerCornerXPlusYPlusPnt)
        sketch.sketchPoints.add(centerCornerXPlusYMinusPnt)
        sketch.sketchPoints.add(centerCornerXMinusYPlusPnt)
        sketch.sketchPoints.add(centerCornerXMinusYminusPnt)
        #center Top Points.
        sketch.sketchPoints.add(centerTopPnt)
        sketch.sketchPoints.add(centerTopXMinusPnt)
        sketch.sketchPoints.add(centerTopXPlusPnt)
        sketch.sketchPoints.add(centerTopYMinusPnt)
        sketch.sketchPoints.add(centerTopYplusPnt)
        sketch.sketchPoints.add(centerBotomPnt)
        sketch.sketchPoints.add(centerBotomXMinusPnt)
        sketch.sketchPoints.add(centerBotomXPlusPnt)
        sketch.sketchPoints.add(centerBotomYMinusPnt)
        sketch.sketchPoints.add(centerBotomYplusPnt)
        if drawBox:
            lines = sketch.sketchCurves.sketchLines
            pnt1 = adsk.core.Point3D.create(smallPnt.x, largePnt.y, smallPnt.z)
            line = lines.addByTwoPoints(smallPnt, pnt1)
            line.isConstruction = True
            pnt1 = line.endSketchPoint
            smallPntSKT =line.startSketchPoint
            pnt2 = adsk.core.Point3D.create(smallPnt.x, smallPnt.y, largePnt.z)
            line = lines.addByTwoPoints(smallPnt, pnt2)
            pnt2 = line.endSketchPoint
            pnt3 = adsk.core.Point3D.create(largePnt.x, smallPnt.y, smallPnt.z)
            line = lines.addByTwoPoints(smallPnt, pnt3)
            pnt3 = line.endSketchPoint
            pnt4 = adsk.core.Point3D.create(smallPnt.x, largePnt.y, largePnt.z)
            line = lines.addByTwoPoints(largePnt, pnt4)
            pnt4 = line.endSketchPoint
            pnt5 = adsk.core.Point3D.create(largePnt.x, largePnt.y, smallPnt.z)
            line = lines.addByTwoPoints(largePnt, pnt5)
            pnt5 = line.endSketchPoint
            pnt6 = adsk.core.Point3D.create(largePnt.x, smallPnt.y, largePnt.z)
            line = lines.addByTwoPoints(largePnt, pnt6)
            pnt6 = line.endSketchPoint
            line = lines.addByTwoPoints(pnt1, pnt4)
            line = lines.addByTwoPoints(pnt1, pnt5)
            line = lines.addByTwoPoints(pnt2, pnt4)
            line = lines.addByTwoPoints(pnt2, pnt6)
            line = lines.addByTwoPoints(pnt3, pnt5)
            line = lines.addByTwoPoints(pnt3, pnt6)
            # End the base feature edit.
                baseFeature.finishEdit()
def getPath(ent):
    path = ''
    if ent.assemblyContext:
        occ = ent.assemblyContext
        while occ:
            if path == '':
                path = occ.name
            else:
                path = occ.name + '/' + path
            occ = occ.assemblyContext
        path = 'Root/' + path
    else:
        path = 'Root'
    return path
kandennti
Hi @pedro_babo .
I am not sure of the details due to lack of information, but I believe you are using CommandDefinitions.addButtonDefinition to create an add-in that uses a dialog.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-04eb6198-72cd-4430-a6a4-8d68a1105b8e
I remember crashing when using the UserInterface.selectEntity method with a dialog.
I would recommend using SelectionCommandInput to create the dialog instead of the selectEntity method.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-8B9041D5-75CC-4515-B4BB-4CF2CD5BC359#Selecti...
pedro_babo
Hi  @kandennti .
Thanks for the reply this is the first time i convert a script to one adin I will investigate.
pedro_babo
Hi  @kandennti .
The API no longer crash.
I’ve added selection input. But now it’s doing nothing. I have the Idea that I’m not getting the correct way the selected Body.
    # Create a simple selection command.
    bodySelection = inputs.addSelectionInput('SelectedBody', 'Select the body', 'Select one body or MeshBody')
    bodySelection.addSelectionFilter(adsk.core.SelectionCommandInput.Bodies)
I’m using to get the selected data
    # Get selected body
    inputs = args.command.commandInputs
    bodySelection: adsk.core.SelectionCommandInput = inputs.itemById('SelectedBody')
but this fails to get BodyRep or from the selection.
    if isinstance(bodySelection.selection, adsk.fusion.BRepBody):
        brepBody = adsk.fusion.BRepBody.cast(bodySelection.selection)
        body = brepBody
        _ui.messageBox('Body')
    elif isinstance(bodySelection.selection, adsk.fusion.MeshBody):
        meshBody = adsk.fusion.MeshBody.cast(bodySelection.selection)
        body = meshBody
        _ui.messageBox('Mesh')
The objective is to get the bounding box of the selected body.
Could someone help here?
j.han97
Hi @pedro_babo,
 is a function to get one of the selections with specified index. Let's say your selection input (i.e., bodySelection) has only 1 selected item, you can get the bRepBody with
bodySelection.selection(0).entity
Please refer to the documentation here for more information:
Fusion 360 Help | SelectionCommandInput.selection Method | Autodesk
pedro_babo
Hi  @j.han97 and @kandennti
It's working many thanks.
    if isinstance(bodySelection.selection(0).entity, adsk.fusion.BRepBody):
        brepBody = adsk.fusion.BRepBody.cast(bodySelection.selection(0).entity)
        body = brepBody
    elif isinstance(bodySelection.selection(0).entity, adsk.fusion.MeshBody):
        meshBody = adsk.fusion.MeshBody.cast(bodySelection.selection(0).entity)
        body = meshBody
Regards
