Get the value of a joint selected
JHRendon
JHRendon
Hi! How can i get the value of a joint that i selected?
I want to select a revolute joint and then appear a message box with the value of that revolute joint.
kandennti
Hi JHRendon.
try it.
#Fusion360API Python script
#Author-kantoku
#Description-RevoluteJointType GetAngleValue test
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app  :adsk.core.Application = adsk.core.Application.get()
        ui   :adsk.core.UserInterface = app.userInterface
        msg :str = 'Select a Revolute Joint'
        selFiltter :str = 'Joints'
        sel :adsk.core.Selection = SelectEnt(ui, msg ,selFiltter)
        if sel is None:
            return
        jnt :adsk.fusion.Joint = sel.entity
        ang :adsk.fusion.ModelParameter = jnt.angle
        msg = 'jointName : {}\nexpression : {}\nvalue : {} rad'.format(
            jnt.name, ang.expression, ang.value)
        ui.messageBox(msg)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def SelectEnt(
        ui :adsk.core.UserInterface,
        msg :str,
        filtter_str :str) -> adsk.core.Selection :
    while True:
        try:
            selection = ui.selectEntity(msg, filtter_str)
            jointType = selection.entity.jointMotion.jointType
            if jointType is adsk.fusion.JointTypes.RevoluteJointType:
                return selection
            ui.messageBox('Please select a Revolute Joint Type')
        except:
            return None
About units
 'expression' property → degree(string)
 'value' property → radian(float)
JHRendon
You're great! 😄
