Get list of selected objects
grakoczy
grakoczy
Is there any way to get list of selected bRepBodies or to check if body is selected?
I've found Selection, but how to use it in the python code?
Grzegorz Rakoczy
ekinsb
The current set of selected entities can be obtained through the UserInterface.activeSelections property.  This is demonstrated in the code below that looks through the currence selections to see if any bodies are selected and then displays information about any selected bodies and any other entity types that were selected.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        result = ''
        for selection in ui.activeSelections:
            selectedEnt = selection.entity
            if selectedEnt.objectType == adsk.fusion.BRepBody.classType():
                result += 'Selected Body: ' + selectedEnt.name + '\n'
            else:
                result += 'Other selection: ' + selectedEnt.objectType + '\n'
        ui.messageBox(result, 'Selection Result')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
Mod the Machine blog
grakoczy
Thanks, this is what I needed.
