Get center point coordinates of selected objects
haraldXAY5Z
haraldXAY5Z
Hello!
I've designed a LED installation in Fusion 360, and now I'm about to map all the LED pixels in a 2D coordinate space.
My very boring and tedious method at the moment is to click one and one object (representing a pixel) with the measuring tool, and the copying the x and y coordinates to an excel sheet. My installation has more than 400 pixels, so this is quite a ****ty job to.
I'm dreaming of a script or add-in that lets me select all the objects in question, and then exports the center coordinate to a csv-file for me. It would literally save me hours of work.
Is there anyone who can help me out with this?
BrianEkins
It should be a fairly simple program, but it depends on what kind of object you're using to represent a pixel.  Is it a body, a construction point, a component, a sketch point, or maybe even something else?
Brian Ekins
haraldXAY5Z
I'm also imagining it should be fairly simple, but I don't have any experience with making add-ins or scripts for Fusion.
At the moment I'm using cylindrical objects to represent the pixels. Then I open the measure tool and select the top face of the cylindrical object and copy the centre points X, Y, and/or Z coordinate.
The reason I'm using objects is because I can copy objects along a path. I don't know about any method of placing points or sketch shapes along a path.
BrianEkins
Can you attach a simple example of a design?  A cylinder could be represented by just a body or it could be an occurrence that references a component that contains the body.  Having access to the design would answer the question very easily.
Brian Ekins
haraldXAY5Z
Yes, I can do that 🙂
Heads up: the file is quite a mess!
The bodys representing the pixels are the last ones in the list: body178 to body654. They can be hard to see if you are zoomed out, but they are located around the origin point.
I've uploaded both the design in question, and a screencast where you can see what I do.
