Generating a 2D Top View from a 3D Design Script in Fusion 360
dedesss2002_1
Observer Observer
dedesss2002_1
Observer
Observer
Hi, I'm using a python script in Fusion 360 to generate a 3D design, but I want to modify it to also create a 2D top view of the same design within the same script. Right now I am getting the 2d view from the tool bar by clicking on Design > Drawing > From Design but I want this job to be done by the script itself that is giving me a 3d design. I'm fairly new to coding so with some help from AI and appropriate multiple prompting, I have managed to get the script to produce the desired results up till now. However, when I use AI to edit the same script that includes the 2D top view, I keep encountering an error indicating that the current Fusion 360 API does not support this functionality.
Can anyone help me find a solution or workaround to generate a 2D top view programmatically from the same script that gives 3d design in Fusion 360?
Below I have attached the 3d design and what I want in 2d.
mohammed.aliTDPXK
Hello @dedesss2002_1 ,
This is not yet supported workflow as far as I know, let me check with the team if there can be any workaround for this.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
mohammed.aliTDPXK
Right now we dont support this workflow, just to mention we already have this item in our backlog and I have shared the forum post as well with the team. I cannot make sure when we will get this workflow working but just to let you know I have already raised a concern with the respective team and probably will update you soon on this
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
dedesss2002_1
Observer
Observer
Thank you so much. Much appreciated.
