fusion2urdf: Missing Joint Origin, can't generate urdf script
sioldead
sioldead
Hello, I am working on creating a URDF file for a prototype robot arm that I assembled in Fusion 360 with STL files. I converted them all to solid bodies which made assembly possible, and I thought that I created my joints as required. However when I try to export the file to a URDF, it gives me an error and says that the first rev joint does not have a joint origin. I tried to create a test assembly and actually used the "Joint Origin" command, and it gave the same error. So far I have found nothing that really answers this problem, so I thought that I would give the forums a try.
I have attached some screenshots of the error message along with the joint and where it is positioned. If there are any more screenshots that I can upload to help out please let me know.
Also please note that this is my first time using Fusion 360 ever, and first time cadding in general in about 8 months. So if this is a very simple fix I apologize, however I really need to figure this out asap. Thank you all.
BrianEkins
It certainly doesn't hurt to ask your question here, but this forum is intended for questions about Fusion's programming interface. I think you'll be lucky to find someone with in-depth knowledge about the Fusion2urdf add-in. It uses the API but has a lot of logic inside it that I don't know anything about. You could possibly file an issue on the GitHub page for the add-in but it looks like it's not actively being developed any longer.
Brian Ekins
storeyp
Hi @sioldead is this still a problem for you? I see I'm joining the conversation a month late.
If so, could you send the .f3d file? (File > Export). We experimented with this add-in a year or two ago, so the screenshots don't immediately spark a memory for me of the problem, but I can try a few things my end.
Out of interest, what's your end goal for getting the URDF files out? Is it for a ROS application or something else?
sioldead
Hey, I managed to figure out how to create the script. I cant really say what specifically I changed in my design, as I was messing around with a few different settings and trials, and it ended up working. I can now repeat it no problem too which is great. As for the application, yes the end goal was to use the URDF for a ROS based project that I am working on. Thank you for the reply.
rulshi55
Community Visitor
Community Visitor
We have to follow specific design practices to get the fusion to URDF  plugin working,
We should mention at least one component as base_link , and setting up the origin and orientation as ROS /Gazebo coordinate system is different from the Fusion360 XYZ, You can refer to this link to get more clarity and easy steps for the same .
