Fusion crashing after importing file from local storage(.f3d)
mayur_kapadnis
mayur_kapadnis
def ImportFile(input_data: dict) -> dict:
    input_data = {"fileName": <fileName>}
    output_data = {"status": <True/False>, "message": <message>}
    try:
        # Extract the file name from input_data
        fileName = input_data["fileName"]
        # Check if file exists
        if not os.path.isfile(fileName):
            return {"status": False, "message": f"File '{fileName}' does not exist."}
        # Get the application object
        app = adsk.core.Application.get()
        design = adsk.fusion.Design.cast(app.activeProduct)
        # Get the root component of the active design (assembly)
        rootComp = design.rootComponent
        # Get import manager
        importManager = app.importManager
        # Get archive import options
        archiveOptions = importManager.createFusionArchiveImportOptions(fileName)
        # Log before importing
        print(f"Attempting to import '{fileName}'...")
        # Import the archive file into the current assembly
        importManager.importToTarget(archiveOptions, rootComp)
        doc = app.activeDocument
        doc.close(False)
        return {"status": True, "message": f"File '{fileName}' imported successfully into the assembly."}
    except Exception as e:
        return {"status": False, "message": f"Failed to import file: {traceback.format_exc()}"}
I am trying to import f3d file from local storage into fusion active document, but fusion app gets crashed
Jorge_Jaramillo
Where from in your script are you calling the ImportFile() function? and what input_data are providing to it?
Did you get some exception information from it?
Also, are you aware of the warning I highlighted in the following image from the API documentation?
Could it be this escenario?
Jorge
kandennti
Hi @mayur_kapadnis -San.
I tried it and was able to import it without any problems.
Can the f3d file you are trying import be manipulated in the GUI?
