fusion api sketches lines
grosfaignan
grosfaignan
hi there, i need to create some lines in python scripts, then add them length and then add them dimension (placement) from origin, how can i do that ?
thanks
Rushikesh.kadam
@grosfaignan here are some sample links that demonstrate creating sketch lines and adding sketch dimensions.
Here is another link explaining the sketch dimensions object https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-GUID-ea0faa88-65eb-4845-b2ce-22d0640bedf4 .Under the topic Samples, there few more examples related to dimension.
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
Jorge_Jaramillo
Hi @grosfaignan ,
Here you have a fragment of python code to create sketch lines and dimension one of them with a user parameter:
app: adsk.core.Application = adsk.core.Application.get()
DISTANCE_PARAMETER = 'distance'
design = adsk.fusion.Design.cast(app.activeProduct)
# 1) user parameter
distParam = design.userParameters.itemByName(DISTANCE_PARAMETER)
if not distParam:
    # create user parameter if not found
    distVal = adsk.core.ValueInput.createByString('35 mm')
    distParam = design.userParameters.add(DISTANCE_PARAMETER, distVal, 'mm', '')
# 2) sketch
rootComp = adsk.fusion.Component.cast(design.rootComponent)
# Create a new sketch on the xy plane.
sketches = rootComp.sketches
sketch = sketches.itemByName('xySketch')
sketch.areDimensionsShown = True  #display dimensions on the sketch
if not sketch:
    # create sketch if not found
    xyPlane = rootComp.xYConstructionPlane
    sketch = adsk.fusion.Sketch.cast(sketches.add(xyPlane))
    sketch.name = 'xySketch'
    # 3) create sketch points
    p1 = sketch.sketchPoints.add(adsk.core.Point3D.create(1, 0, 0))
    p2 = sketch.sketchPoints.add(adsk.core.Point3D.create(3, 1, 0))
    # 4) create 2 lines, sharing p1 as a coincident constraint
    line1 = sketch.sketchCurves.sketchLines.addByTwoPoints(sketch.originPoint, p1)
    line2 = sketch.sketchCurves.sketchLines.addByTwoPoints(p1, p2)
    # 5) add dimension to line1
    sld = sketch.sketchDimensions.addDistanceDimension(sketch.originPoint, p1, adsk.fusion.DimensionOrientations.AlignedDimensionOrientation, adsk.core.Point3D.create(0, 2, 0))
    # 6) get model parameter from the sketch dimension and assign a user parameter to its expression
    modelParam = adsk.fusion.ModelParameter.cast(sld.parameter)
    modelParam.expression = DISTANCE_PARAMETER
This is the result:
Hope it helps.
Let me know if it works for you.
Jorge
Jorge_Jaramillo
Please correct in the previous code, moving this line :
after
sketch.name = 'xySketch'.
Sorry!!.
