Fusion API - Show Message Box When Document (Assembly, Part or Drawing) Is Opened
isocam
isocam
Can anybody help?
Does anybody know how, using a Fusion Python script, show a message box whenever a Fusion document (Assembly, Part or Drawing) is opened?
I just need this code for testing.
Many thanks in advance!
Kindest Regards
Darren
boopathi.sivakumar
Hi @isocam
You can use the eventHandlers to do this I suppose if you are creating an add-in then you can hook on to application.documentOpened event then you can handle the logic inside the notify function of the class you are hooked into it.
here is the documentation
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-270c87f0-04d7-4bd8-9632-0e025d68df39
Boopathi Sivakumar
Senior Technology Consultant
