Fusion API Error when getting Chamfer Edge Set
robertASTUP
robertASTUP
I am trying to get out the edge set for a chamfer in the attached model. When I create the chamfer by selecting a face and run the below script, I get a "RuntimeError: 2 : InternalValidationError : dataRef" error. When I select all 4 edges to form the edge set, this runs with no issues. Is this a bug in the API or does the script need modified for if the edge sets contain faces or edges?
import adsk.fusion, adsk.core
app = adsk.core.Application.get()
design = adsk.fusion.Design.cast(app.activeProduct)
timeline = design.timeline
chamfer = timeline.item(1).entity
# roll timeline to before chamfer
timeline.item(1).rollTo(True)
# get edge sets
edge_sets = chamfer.edgeSets
print(edge_sets.item(0).edges)
john.kirchner
This looks like a bug in the API, you shouldn't need to check in your script if the chamfer's edge sets contain faces, edges, etc before grabbing the edges.
I have reproduced the issue on my end and have created a bug ticket, thank you for posting this!
