Fusion 360 Script Error: "(filename) is an active document"
don_tonny_123
don_tonny_123
Hi everyone,
I'm experiencing a persistent issue when trying to run a Python script in Fusion 360. I keep getting the error message:
AttributeError: 'NoneType' object has no attribute 'isActive'
or
No active document / No active product
Here's what I've tried so far:
I start Fusion 360 normally
I create a new design via File → New Design
I do NOT open the script dialog first
Then I go to Utilities → Scripts and Add-Ins, select my script, and click Run
The script crashes immediately with the error that no active design/product is found
Even with this minimal test script:
app = adsk.core.Application.get()
ui = app.userInterface
if not app.activeDocument:
ui.messageBox("No active document found")
return
…I still get the same error, even though a new design is definitely open.
I’ve already:
Reset Fusion settings
Cleared the cache folders
Disabled all add-ins
Reinstalled Fusion 360
Nothing helps.
Has anyone else encountered this issue or found a workaround?
Any ideas would be greatly appreciated!
Thanks in advance.
Fusion 2601.1.34 x86_64
Aktiver Plan: Privatanwender
Windows 11 Home 23H2 (22631.5126)
don_tonny_123
Hi everyone,
or
return
I’ve already:
Nothing helps.
Thanks in advance.
kandennti
Hi @don_tonny_123 -san.
After creating a new script, it looks like this.
"""This file acts as the main module for this script."""
import traceback
import adsk.core
import adsk.fusion
# import adsk.cam
# Initialize the global variables for the Application and UserInterface objects.
def run(_context: str):
    """This function is called by Fusion when the script is run."""
    try:
        # Your code goes here.
        ui.messageBox(f'"{app.activeDocument.name}" is the active Document.')
    except:  #pylint:disable=bare-except
        # Write the error message to the TEXT COMMANDS window.
        app.log(f'Failed:\n{traceback.format_exc()}')
I created a new document and ran the script and got the same result as the image you attached. I don't see anything wrong with it.
If there is a problem, please provide the actual code you ran.
don_tonny_123
Hello Kandennti,
As an example, this code creates a small curved component. After execution, this message appears, but the component is not displayed.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        # 🔥 NEU: Dokument sicherstellen
        design = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        design = app.activeProduct
        rootComp = design.rootComponent
        # Maße
        length = 220.0 # Länge in mm
        width_front = 60.0 # Breite vorne
        width_rear = 70.0 # Breite hinten
        thickness = 3.0 # Materialstärke
        # Trapez-Skizze erstellen
        sketches = rootComp.sketches
        xyPlane = rootComp.xYConstructionPlane
        sketch = sketches.add(xyPlane)
        # Punkte für Trapez
        points = adsk.core.ObjectCollection.create()
        points.add(adsk.core.Point3D.create(0, 0, 0))
        points.add(adsk.core.Point3D.create(length, 0, 0))
        points.add(adsk.core.Point3D.create(length, width_rear, 0))
        points.add(adsk.core.Point3D.create(0, width_front, 0))
        # Linien zeichnen
        sketch.sketchCurves.sketchLines.addByTwoPoints(points.item(0), points.item(1))
        sketch.sketchCurves.sketchLines.addByTwoPoints(points.item(1), points.item(2))
        sketch.sketchCurves.sketchLines.addByTwoPoints(points.item(2), points.item(3))
        sketch.sketchCurves.sketchLines.addByTwoPoints(points.item(3), points.item(0))
        # Extrudieren
        extrudes = rootComp.features.extrudeFeatures
        profile = sketch.profiles.item(0)
        extrudeInput = extrudes.createInput(profile, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        extrudeInput.setDistanceExtent(False, adsk.core.ValueInput.createByReal(thickness))
        extrude = extrudes.add(extrudeInput)
        # Sheet Metal aktivieren
        sheetMetal = design.fusionSheetMetal
        if sheetMetal.sheetMetalRules.count == 0:
            sheetMetal.addSheetMetalRule()
        sheetMetalRule = sheetMetal.sheetMetalRules.item(0)
        sheetMetalRule.thickness = thickness
        ui.messageBox('Biegung R620 manuell im Sheet Metal-Werkzeug hinzufügen!')
    except:
        if ui:
            ui.messageBox('Fehler:\n{}'.format(traceback.format_exc()))
kandennti
I checked and found that there is no method to create a new sheet metal rule.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-BFE11BED-D717-415F-B401-3F0769F7673E
Therefore, we are using a text command to force a solid body to become a sheet metal body to create a sheet metal rule.
        # Extrudieren
        # sheetMetal = design.fusionSheetMetal
        # if sheetMetal.sheetMetalRules.count == 0:
        #     sheetMetal.addSheetMetalRule()
        # sheetMetalRule = sheetMetal.sheetMetalRules.item(0)
        # sheetMetalRule.thickness = thickness
        ui.activeSelections.clear()
        ui.activeSelections.add(extrude.endFaces[0])
        app.executeTextCommand(u"Commands.Start ConvertToSheetMetalCmd")
        app.executeTextCommand(u"NuCommands.CommitCmd")
