Fusion 360 crashes when updating TextBoxCommandInput from another thread
I am running into an issue where Fusion 360 crashes (Completely, with Autodesk crash report popping up) when trying to update text from another thread
I am doing something in the background that takes a bit, so I am executing the action from another thread. I want to show the progress of the execution, so I have a text box where I display the percentage.
t = Thread(target=self.progressBarCallback, args=(progress,))
t.start()
This crashes Fusion. The callback is just a function that updates the input's formattedText:
self._input.formattedText = "<b align='center'>{}</b>".format(percent)
Not sure what causes this. Maybe it takes a long time to render the formatted text, and I'm updating too quickly, although slowing it down to once every second doesn't fix the issue either.
When I update a different CommandInput, like a BoolCommandInput's text, it doesn't crash and it updates perfectly fine from another thread and with hundreds of updates a second.
Is there some other way? I wanted to use the formattedText's html features to render a progress bar, but it doesn't seem like I can do that if it can't even handle text. Is there another way to put HTML snippets in?
KrisKaplan
All of the User Interface APIs are only supported to be called from the main/UI thread. (There really should be a check for this and a better error returned instead of allowing it to crash.)
You can still do processing on worker threads, but I would suggesting triggering a CustomEvent from your worker thread to trigger a CustomEventHandler on the main thread to update any UI elements.
Kris
Kris Kaplan
