Fusion 360 api create thumbnail wireframe
n.michiels
n.michiels
Hello All,
I use this method to create thumbnails of my components.
returnValue = component_var.createThumbnail(width, height, imageType)
I would also like to create thumbnails of my components, but then with visual style wireframe.
something like this:
Is this possible?
Thanks.
Kind regards,
Nick
BrianEkins
Unfortunately, the only way would be to change the render settings in Fusion, render it in the graphics window, and save the result. I don't know whether the underlying machinery the API uses to support createThumbnail supports the different rendering types, or whether the API just doesn't provide that option.
Brian Ekins
MichaelT_123
Hi Mr N.Michiels,
The wireframe effect can be achieved by applying an "air" (or similar) appearance to the component/body.
Changing the <Display Setting><Visual Styles> to <Wireframe> should produce a similar (if not identical) effect for the whole design.
A wireframe representation of organic bodies does not always produce a desirable outcome, though.
I also see an additional path: using direct script programming for component/body outlays.
Look at the sample in the API docs: "BRep Body definition Sample".
Proceed with it ... but only if you can resist insanity.
Regards
MichaelT
MichaelT
n.michiels
Thank you for the reply
