Fully Automating Design from CAD to CAM with Fusion 360 API
akimmelUYSQM
Observer Observer
akimmelUYSQM
Observer
Observer
Hello!
I am a PhD student at Carnegie Mellon University and we are interested in fully automating a manufacturing process for a part using the Fusion 360 API. By fully automating I mean zero human interaction, especially for the CAM part. It seems like in order to use the CAM API today you must generate pre-existing templates and manually assign features (like holes) to their corresponding CAM operations.
Is there a way to automate this that exists or is in the works?
If not, I'm trying to find a large dataset of pre-defined parts with their full toolpaths, CAM operation files, setups, and cost analysis so we can use machine learning to take a CAD file and automatically generate CAM operations without any human clicking to tell the computer where to drill what feature. Also, I would like to see the content of a CAM operation template file NOT through some GUI. I need to see the actual contents of the file, whether in byte code or some other encoding. Is there a way for me to download them to my local computer and open them with some sort of text editor?
Thanks!
BrianEkins
Unfortunately, the current CAM API is incomplete and it's not possible to do what you described. Hopefully, we'll see some additional functionality in the not too distant future.
Brian Ekins
akimmelUYSQM
Observer
Observer
If that is the case, is it possible for us to have a set of complete CAD design with CAM operation + toolpath files so we could try to use ML to generate CAM operations for a certain design? Do you know where we could get such a data set?
BrianEkins
I'm not certain what you're looking for but if it's what I think it is, I'm not aware of anything like that publicly available. You would need to create your own designs and machining definitions.
Brian Ekins
akimmelUYSQM
Observer
Observer
Yeah, I'm basically looking for a large repository of both the CAD designs and their corresponding CAM operation files/toolpaths. It seems like there are large repositories of CAD designs alone but not ones with their matching manufacturing information. Thanks for your help!
Cave_Master
There is a lot of CAM samples included with Fusion.   Also a lot of people post designs and toolpaths into the forums.
Its going to be a tough thing to automate as there are many parameters which are dependent on individual machine, materials, and tool selection.
ArjanDijk
There is no way to do contour selection from that API so there is your main limitation. There are some possibilities to full automate a process but a requires parts that are a bit predictable and can work without manual selection of contours. In this case you might even have to accept that you manually have to app a few finishing steps.
What you can do:
  1. Use 2D contour/Adaptive/pocket with pocket recognition with a certain set of limitations that suit your model
  2. Use 3D pocket/adaptive to auto machine your parts on generation
  3. Use 3D pocket/adaptive with smaller tools and rest machining to clear the smaller area's
  4. Use Drill/Bore with diameter range to autoselect holes in a certain range
  5. Use Flat machine to finish flat surface
Apply these from a template and you can automate as much as Fusion allows you today
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
