Failed to select a cylinder-face as geometry for a drill operation
maurizio_manzi
Message 1 of 9
maurizio_manzi
I create a drill operation and select my cylinder-Face as geometry (drill position),
but in the line "selection = cadcontours.getCurveSelections()" I get an error message:
"AttributeError: 'CadObjectParameterValue' object has no attribute 'getCurveSelections'"
Code:
# drillFace is my cylinder-face (I can select it manually in the operation)
operationInput = setup.operations.createInput('drill')
operationInput.tool = toolDrill
op_drill = setup.operations.add(operationInput
op_drill.parameters.itemByName('holeMode').expression = "'selection-faces'"
cadcontours: adsk.cam.CadContours2dParameterValue = op_drill.parameters.itemByName('holeFaces').value
selection = cadcontours.getCurveSelections() # <<<--- Error see below
faceContourSel: adsk.cam.FaceContourSelection = selection.createNewFaceContourSelection()
contour selection
faceContourSel.inputGeometry = [drillFace]
cadcontours.applyCurveSelections(selection)
# ERROR:
#selection = cadcontours.getCurveSelections()
#AttributeError: 'CadObjectParameterValue' object has no attribute 'getCurveSelections'
Best regards
Maurizio
Replies (8)
Message 2 of 9
kandennti
Hi @maurizio_manzi .
"op_drill.parameters.itemByName('holeFaces').value" is "CadObjectParameterValue" instead of "CadContours2dParameterValue".
Therefore, it must be done this way.
        op_drill = setup.operations.add(operationInput)
        # cadcontours: adsk.cam.CadContours2dParameterValue = op_drill.parameters.itemByName('holeFaces').value
        cadcontours: adsk.cam.CadObjectParameterValue = op_drill.parameters.itemByName('holeFaces').value
        # selection = cadcontours.getCurveSelections() # <<<--- Error see below
        # faceContourSel: adsk.cam.FaceContourSelection = selection.createNewFaceContourSelection()
        # contour selection
        # faceContourSel.inputGeometry = [drillFace]
        # cadcontours.applyCurveSelections(selection)
        cadcontours.value = [drillFace]
Message 3 of 9
maurizio_manzi
Thank you very much for help.
I create the cylinder surface for the drill operation as a revolve:
# Create surface as rotation:
revolves = occComp.features.revolveFeatures
revInput = revolves.createInput(profile, axis, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
angle = adsk.core.ValueInput.createByReal(math.pi*2)
revInput.setAngleExtent(False, angle)
revInput.isSolid = False
ext = revolves.add(revInput)
Now I try to use the revolve ("ext") as surface for the drill operation:
drillFace = ext # Revolve as Face for drill operation
op_drill = setup.operations.add(operationInput) # Add Operation
But I get in the operation an error message (see pic below).
I think, I can't use directly the revolve as face for the drill operation.
How can I get a valid face from my revolve operation ?
Best regards
Maurizio
Message 4 of 9
kandennti
@maurizio_manzi .
As with all questions, it takes too much time to reproduce the same condition rather than looking for the cause.
Could you please attach the f3d file?
Message 5 of 9
kandennti
@maurizio_manzi .
It should be a BRepFace listing, not a RevolveFeature.
        # drillFace = ext # Revolve as Face for drill operation
        drillFaces = [f for f in ext.bodies[0].faces]
        # cadcontours.value = [drillFace]
        cadcontours.value = drillFaces
There may be other causes, but we cannot be sure without seeing the data.
Use this one because the indentation is broken.
Message 6 of 9
maurizio_manzi
Message 7 of 9
maurizio_manzi
How can I create this dump myself ?
Message 8 of 9
kandennti
@maurizio_manzi .
Thanks for the data.
I gave up because I don't know what "profile" and "axis" are.
Message 9 of 9
maurizio_manzi
It works fine, with:
 Thank you very much.
How can I see this dump in my VS-code ?
Best regards
Maurizio
