Expand a setup from the API
jan_weidner
jan_weidner
In Fusion360 I can expand and collapse setups by clicking on the |> icon next to them:
Can I also expand and collapse from the API?
kandennti
Hi @jan_weidner -San.
I found text commands to expand and collapse.
This is an example of collapsing all Setup, not Setups.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import adsk.cam as cam
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        camObj: cam.CAM = app.activeProduct
        sels: core.Selections = ui.activeSelections
        sels.clear()
        for setup in camObj.setups:
            sels.add(setup)
            app.executeTextCommand(u"NaNeuCAMUI.CollapseAllChildren")
            sels.clear()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The deployment requires a little ingenuity because it all unfolds.
import traceback
def run(context):
    try:
        sels.clear()
            sels.add(setup)
            app.executeTextCommand(u"NaNeuCAMUI.ExpandAllChildren")
            sels.clear()
            for ope in setup.operations:
                sels.add(ope)
                sels.clear()
    except:
        if ui:
jan_weidner
Wow it would never occured to me to it like this, thanks!
